Aircon not working diagnosis
Re: Aircon not working diagnosis
Well it all looks professional. No idea what I’m doing though.
The high pressure side starts at >150psi or so and then drops once it's got going and the air is cold.
I suspect I’ll be buying a vacuum pump soon, just because...
High side seems a bit low. What are your static pressures (engine off and cold)?
Yeah, it started higher and then dropped. It does pump out proper cold air though - so something is working.
I thought I took a pic of the pressure engine off & all cold - but fat fingers. Will have another go.
This is with AC set to max cold, right?
You'd need a gas recovery system, too, if you intend to do any work on the system. And a way to accurately measure the amount of gas (and PAG oil) to go back in.
I thought it was just a good set of scales to measure gas going back in?
Anyway, I should stop this line of thought. I have enough tools in the garage as it is....if it's broken, I'll fix it and then get kwikfit or whoever to vacuum & recharge it with the machine.
Which reminds me of the fix on my old Saab. The high pressure line had corroded through from before we bought it. So I rigged up an adaptor to the compressor to pressurise it and find the leak. Then a bit of JB Weld, couple of hose clamps and a bit of tube that fit snugly round the outside to make a patch and bingo - aircon fixed without having to take the whole front of the car off, not even the bumper, to get working aircon again.
Brilliant. I am pretty sure this is what has happened to my 9000, a lot of corrosion around the high pressure switch. Anyway, it all looks far too corroded to try and fix. Suspect I am going to let the car go after the next MOT anyway.
Engine off and cold.
Looks about right. But there’s only so much you can tell from the pressures.
Users browsing this forum: Google [Bot], MeTsU, srichards, steve2003rs6 and 366 guests
