Suspension ride height
- Top Gear
Re: Suspension ride height
Hardly ever have music on. Love to listen to the v8. To me that’s all the music I need.
Ps still cannot get over the pedal box fix.
What a transformation.
Best tip ever.
Best tip ever.
That's what bams missus says to him, cause that's all he's got.
- Top Gear
Also while fixing the cable ties I found a aftermarket alarm system that I didn’t know I had. And a small on off rocker switch. Need to find out what this is for.
Typical Rs6 behaviour. Solve 1 problem and find 2 others.
- Top Gear
Car booked in at Neston for 06/07/21 for the two oil leaks.
Spoke to grizz about the pedal box fix.
Original bushes are plastic.
Repair was to use p b bushes.
Will see if I can get some bushes manufactured.
Apparently there is a long bolt that goes through the shaft which can be a pain to remove.
The factory lock tight it in.
Fecking awesome. Bring on the Poosey Bush!
- Top Gear
Ha ha. That’s sounds even better than the pipe.
Now wait for chunkeys, matts and bam bams contribution.
I don’t mind signing up for some poosey bush
When you remove your shaft, make sure you sufficiently polish it. Give it a liberal lubing then slam it back into your new tight Poosey Bush.steve2003rs6 wrote: ↑Wed Jun 23, 2021 2:23 pmCar booked in at Neston for 06/07/21 for the two oil leaks.
- Top Gear
Still cannot get over the pedal box fix.
The drive is amazing. I just keep jumping in the car and going for a drive. It is that good that I just keep on going.
My fuel bill has quadrupled though.
Enquired about buying a second hand pedal box assy
So that we can make bushes
See if anything comes of it.
Hi steve
Told you it would be the best 50p you would ever spent .
Glad it sorted for you and your enjoying the car again
- Top Gear
Hi Riggs. Spot on mate. Wouldn’t have expected the pedal box to be my problem.
20 min job and the cost of 5 cable ties and the end result is totally unbelievable.
However it has cost me £200 in fuel since the fix. As I just keep jumping in the car and going for a drive
- Top Gear
Sorry to keep harping on about the pedal box fix.
For a 18 yo car i find it astonishing that it now drives like new.
I was always in love with this car. But now cannot keep out of her. Amazing. Best tip ever and cost less than a quid.
Just thank you to those involved.
Users browsing this forum: EireRS6, Felix2566, Majestic-12 [Bot], steve2003rs6 and 191 guests
