Hi, what's the recommended specs and brand for the rs6?
Thanks!
Steering oil
Steering oil
Re: Steering oil
There's loads - it's relatively bog standard stuff, although not your usual Dexron III. It's called "Central Hydraulic Fluid"
IIRC I have Comma MVCHF in mine at the moment which meets the spec and looks identical to the OEM stuff I've had before.
Re: Steering oil
Forgot to say thanks for the reply, so thank you!
I finally bought this one : https://www.topwagen.com/huile-verte-de ... 28137.html.
