TPMS MHz
Posted: Mon Mar 15, 2021 11:25 am
by anditsoundslikebells
I'm buying some new TPMS and want to be sure I buy the correct ones. I've found conflicting info.
In thread:
"Different part numbers for C5 and C7. C5 are 4D0907275D and uses 315Mhz, C7 are 7PP907275F (433mhz)"
search.php?keywords=315MHz
on ebay:
"Audi RS6 2000 - 2008 TPMS Huf RDE001 Direct Fit 433MHz (NEW)"
https://www.ebay.co.uk/itm/Audi-RS6-200 ... 2991624010
I checked but couldn't find them here:
https://audi.7zap.com/en/rdw/audi+rs6+r ... 601080/#15
From the two options, I guess it's 315MHz?
Can someone share a link to a Huf TPMS that is correct for my '03?
(somewhere I've read another thread in the C5-sub but I can't find it)
Re: TPMS MHz
Posted: Mon Mar 15, 2021 11:28 am
by norwichphoto
Hurrah - one I can answer...
I took the tyres off my alloys on Saturday and the Audi p/n is 4D0 907 275 433mhz. I think they are now HUF RDE001.
Re: TPMS MHz
Posted: Mon Mar 15, 2021 11:33 am
by norwichphoto
Re: TPMS MHz
Posted: Mon Mar 15, 2021 3:55 pm
by Mark-RS
All this is well and good, but I've just noticed in your sig, you have a TVR ! Any pics to share ? :bigblink:
Re: TPMS MHz
Posted: Mon Mar 15, 2021 4:22 pm
by norwichphoto
Easiest to link to the advert.
https://www.pistonheads.com/buy/listing/10729565
Re: TPMS MHz
Posted: Mon Mar 15, 2021 4:38 pm
by norwichphoto
I'm also interested as I'm having my wheels refurbished and I don't know how good the existing sensors are. Searching Autodoc for the 4D0907275 part number gives me Ridex 433mhz sensors at £ 28 each rising to £ 82.61 for HUF ones. Has anyone used the cheap type with success? Seems a big difference for a comparatively crude system that can be turned off easily.
Re: TPMS MHz
Posted: Mon Mar 15, 2021 9:38 pm
by Shoppinit
I bought some Huf RDE001.
The auto doc ones sound like very good value. I’d try those if you’re sure they’re compatible.
Re: TPMS MHz
Posted: Tue Mar 16, 2021 5:32 pm
by norwichphoto
Well I've double checked and they run on the same frequency and all the documentation says they're compatible with the OEM number, so I've ordered a set. Total including valve stems and VAT was £ 131.92 for 4, so £ 32.98 per corner. I don't want to run the car until cambelt is done, so waiting for my turn to borrow the tools, but will report back soon.
Re: TPMS MHz
Posted: Tue Mar 16, 2021 7:04 pm
by Shoppinit
Bargain. Let us know. I might get a set.
Re: TPMS MHz
Posted: Sat Jul 09, 2022 2:54 pm
by simonmcc
Has anybody tried these? https://tpmszone.co.uk/product/tx-s001- ... ms-sensor/
The Schrader sensors on autodoc also look very good value, and I've at least heard of Schrader before: https://www.autodoc.co.uk/schrader/14528209
Re: TPMS MHz
Posted: Tue Oct 01, 2024 4:58 pm
by Shoppinit
Did you try these out?
Re: TPMS MHz
Posted: Tue Oct 01, 2024 5:40 pm
by norwichphoto
Yes. They have proven to work fine. Occassionally get a warning but its generally when its been a really cold day compared and the pressure has just dipped under whatever the tolerance is. I normally run 3 bar pressure.
I got mine from UK Parts Direct, their reference HHS-Audi-RS6-1. https://www.ukpartsdirect.com/audi-rs6- ... o-fit.html
I had new tyres fitted November 2023 - but I think the sensors were reused with new valves / seats.
Re: TPMS MHz
Posted: Tue Oct 01, 2024 5:54 pm
by Felix2566
Was also looking on Autodoc for TPMs, glad that the cheaper ones seem to be working fine, was going to order the Huf ones, but if your ones are working fine dont see the reason for the extra expense, have spent enough on it this year....🙄😅
Re: TPMS MHz
Posted: Tue Oct 01, 2024 6:04 pm
by Shoppinit
Thanks. Not come across that brand before.
