Is this normal ;-)
Is this normal ;-)
Gear lever movement, if not a 'factory feature' any ideas on what's cactus?
https://youtu.be/jZsvlokqymw
Re: Is this normal ;-)
Mine does the twist movement, not sure about the forwards and backwards though.
Daytona RS6 Avant
- Top Gear
Mine doesn’t twist or rock back and forth.
So I presume it isn’t normal.
Definitely not normal. Probably a worn selector mechanism.
Selector mechanism sounds expensive... It works fine, but annoys the <beep> out of me.
They are probably the same for all A6. You could probably find a second hand one easily enough.
I give the yards a look, thanks all.
Mines tight...
Here's another one.
Window clunk when going down, as in when it reaches its stop.
https://youtu.be/oFmTtsdFTHE
Anyone getting this, if not normal what's it a symptom of?
I'm pretty sure mine does that also. I've also replaced the mechanism when the window dropped into the bottom of the door, and I'm still sure it does this.
Thanks Mark. I guess I can put up with it and just imagine its not a clunk per se, more that the car is simply saying "Komplett"
Sounds exactly like mine. You need to dial down your paranoia slightly or you're not going to survive RS6 ownership.
I'm slowly getting there with everyone's help. I actually leaned on it properly for the 1st time since I bought it last year. Quietly brutal.
- Human Joist
The first time you floor it after taking it out the garage after winter I always wince expecting a problem
Last year I blew the oil cooler, swapped failed suspension and blew a water line under the manifold so it got to the every drive I was expecting something and didn’t like leaving it running on the drive incase something else went wrong let’s hope I ironed out those issues and can enjoy it this year
But when they do go, they f'ing go!
