Gearbox issue.
Gearbox issue.
So problem with the box, this has been happening more and more since the weather getting cooler.
The gear selector on the dash goes through all drive selected except D, all the rest no problem, you can see the D flickering when trying to select it.
Drives OK in S and manual.
Box was serviced 6k a go.
When I try and move it back into D after manual all go red.
So after looking through old posts I'm guessing the first 2 are the harness and the other one is a solenoid.
Anyone know audi part numbers for these ?
Any help very much appreciated.
Ps when you click on the pic it straightens up.
Gav.
Gav.
Re: Gearbox issue.
I’d start by changing the F125.
Re: Gearbox issue.
What Shop says!-I had something like this that ended up being a bare wire going into the f125 so check the loomShoppinit wrote:I’d start by changing the F125.
Re: Gearbox issue.
Yeah, if you spot a wire out of place just cut it, innit.
Re: Gearbox issue.
I deserve that!Shoppinit wrote: Yeah, if you spot a wire out of place just cut it, innit.
Re: Gearbox issue.
Thanks lads, just had a look at shopp's write up on this looks like i could try it myself but then again garage would probably do it in a couple of hours...decisions...decisions.
Going to see if I can get the switch fom Audi or are these freely available?
Re: Gearbox issue.
Auto doc £232 ?
Re: Gearbox issue.
Thats for an 8 pin I think ours is 10 ??.
Re: Gearbox issue.
Get it from audi mate it’s about £150 so it’s cheap for a rs6 partGav66 wrote:Thanks lads, just had a look at shopp's write up on this looks like i could try it myself but then again garage would probably do it in a couple of hours...decisions...decisions.
Re: Gearbox issue.
Thanks Jay very much appreciated.
Re: Gearbox issue.
So contacted Audi today and was looking for the part 01L919821B which he said was transmission range sensor but also said thats not the F125 switch which is part number 4bz927156fb gearbox control unit.
He described the 01l919821b as a plate with a cable on it which I think is what is the f125 swith could someone clarify this for me pls before I order it.
Cheers.
Cheers.
Re: Gearbox issue.
Re: Gearbox issue.
Shock horror Audi dealer doesn’t know anything about Audis.
Re: Gearbox issue.
Is this the f125 switch ? No 12 ?
Re: Gearbox issue.
Good so they have that in stock for £215
Users browsing this forum: No registered users and 199 guests
