New Wheels Question
New Wheels Question
Sooooooo - i got myself a set of 19" MTM Alloys. Tyres on them will be 275/30/19
Apparently I have to grind some knobbly bit - any pics of which part of the suspension it is ?
Re: New Wheels Question
Thanks Shop
I thought I went through all the pages of that thread and didn't see those pics.
Anyway - need to get me grinder out
- IchBautAuto
See the word grinder and thought I'd throw in a few crumbs. Make sure that you leave no sharp edges or gouges after you've removed the knob. They can be stress raisers and a start point of failure if done wrong. I finished mine with hand files and paper and kept large radius curves. Might sound a bit pedantic but you wouldn't think that if you ever had an upright fail.
- Human Joist
“Grinder” and “knob”. Shops head will come offIchBautAuto wrote: ↑Sun Oct 25, 2020 10:26 pmSee the word grinder and thought I'd throw in a few crumbs. Make sure that you leave no sharp edges or gouges after you've removed the knob. They can be stress raisers and a start point of failure if done wrong. I finished mine with hand files and paper and kept large radius curves. Might sound a bit pedantic but you wouldn't think that if you ever had an upright fail.
Will be using Dremmel with some smoothing tools so should be OKIchBautAuto wrote: ↑Sun Oct 25, 2020 10:26 pmSee the word grinder and thought I'd throw in a few crumbs. Make sure that you leave no sharp edges or gouges after you've removed the knob. They can be stress raisers and a start point of failure if done wrong. I finished mine with hand files and paper and kept large radius curves. Might sound a bit pedantic but you wouldn't think that if you ever had an upright fail.
I bet his hands are itching alreadyHuman Joist wrote: ↑Mon Oct 26, 2020 9:02 am“Grinder” and “knob”. Shops head will come offIchBautAuto wrote: ↑Sun Oct 25, 2020 10:26 pmSee the word grinder and thought I'd throw in a few crumbs. Make sure that you leave no sharp edges or gouges after you've removed the knob. They can be stress raisers and a start point of failure if done wrong. I finished mine with hand files and paper and kept large radius curves. Might sound a bit pedantic but you wouldn't think that if you ever had an upright fail.
- IchBautAuto
That'll take some time if it's like my dremmel. It is soothing to be able to see a ray of sunshine between the tyre edge and the upright though, even if it is knobless.
I had a set of the mtm bimotos, bought them second hand. They appear to be made from cheese and dent/buckle at the slightest bump. I think the softness is a common thing if you google it - shame as the look great. From memory of used a spacer on mine, not sure of this was for the rubbing or as I run a C6 front brake set up?
that's worrying - with my luck I will bend them within months
And I already have 10mm distances on mine.
The forged ones are much stronger.
I know the forged are about 3 x the price, do you know how to spot them from the normal ones? Mine were definitely not - also note the 20” are listed on QST at £1,585 inc vat for a set - I seem to remember them being more like double that!?? As I say I really like the look of them just the set I had was bent (and from memory pretty heavy)
Hi,
I've got a set of those mtm bimoto, and am very happy with them, both for the look & feel. Tyres are 255/35/R19 here and no grinder job was needed to get a perfect fit and stance.
As far as their strength is concerned they are very solid to my taste (they are rated for a 765kg weight per wheel), but I must confess I finally succeeded to warp one on a (massive) pothole this summer, couldn't find a worse one. Made me buy a spare one that will soon be sent for repair.
OK so Finally
Wheels picked, refreshed and with a brand new set of 275/30/19 MPS4S
So to have the wheels fit had to actually remove the 10mm Spacers and obviously grind down "the knobbly bit". With the spacer they came out too far out
Fantastic looking wheels.
Car looked great as well - just by the time new wheels came in it was already pissing down a lot
Users browsing this forum: No registered users and 327 guests
