VCDS fault codes after clearing
Re: VCDS fault codes after clearing
3 hours is great
I think the C5 is a bit easier, for my D2 S8 it's about 5 hours!
(Though someone we know who's a real D2 expert reckons to do it in 40 minutes!)
So after disconnecting the battery for +24hrs, then reconnecting, retesting and clearing all faults, I took her for a test drive, a bit of fuel and more test driving. The procedure seems to have done the trick as my engine code has remained clear.steve2003rs6 wrote: ↑Fri Aug 14, 2020 12:10 pmFingers crossed for you Chris. Audi tech recently told me that disconnecting the battery resets everything.
That was when I went to him for the cluster backlighting issue.
Unfortunately the ABS code has returned so I will get that booked up with MRC as soon as I’m comfortable that the engine code has gone for good. I’ll also ask them to take a look at the ecu to ascertain if she has been chipped at some point.
Feeling very relieved at the moment. Thanks for all your help guys.
- Top Gear
Let’s hope that it stays off
Nice one buddy.
That ABS error definitely has the strong aroma of a failing F125.
Personally, depending on the mileage you do, I'd ignore it until it actually causes a problem - usually limp mode.
Thanks for the advice.
She’s my daily but I only do 4K miles a year max. She had a full 20k service when I brought the car in May, so providing I don’t have any failures between now and then my next scheduled appointment isn’t for some time.
Keep clearing it and scanning for it reappearing, it'll give you a feel for how quickly it happens.
Users browsing this forum: srichards and 299 guests
