Page 1 of 2
Help
Posted: Thu Feb 06, 2020 7:48 pm
by Matt58
Evening all, got stranded this ev, coming back from work car driving perfect until everything died, managed to wrestle the car to the side of the road and luckily into a safe place. Very scary, no dash lights no hazard light, all dial needles stuck were they were when engine cut out. I did get a brake system warning light first thing this morning, but only for a split second. I did scan car on return journey from work and there was a cafe for EGT 17867 which I'm assuming might be something to do with a faulty maf/maf wiring which I was going to investigate this weekend, cleared code, but left scan tool attached to look at maf readings, then 20 miles later, complete shut down, I've taken the big 150/200 fuses out and look fine other than a small amount of what looks like brake fluid. Any ideas or help would be really appreciated. Matt.
Re: Help
Posted: Thu Feb 06, 2020 8:00 pm
by mikep99
I vaguely remember some weird things going on when I left a bluetooth scanner dongle left in my ODB port.
It only happened on startup though, I disconnected the battery for a while after removing the dongle to make sure any gremlins were out of the system.
Only happened once... been fine since.
Mike
Re: Help
Posted: Thu Feb 06, 2020 8:19 pm
by Matt58
Thanks Mike, just seams strange that everything is dead.
Re: Help
Posted: Thu Feb 06, 2020 8:52 pm
by mikep99
Oh sorry, didnt realise it was still dead,....
Have you tried disconnecting the battery? not familiar with the RS6, but pulling the big fuses may not disconnect the power to the ecu etc...
Pretty sure on the RS4 they split into different circuits - one for the starter, one for everything else.
Mike
Re: Help
Posted: Thu Feb 06, 2020 9:28 pm
by Ajc
Check the mega fuse under the scuttle next too the header tank . There pretty common for becoming wet and green and no longer working
Re: Help
Posted: Thu Feb 06, 2020 9:42 pm
by Matt58
Thanks all, I've removed and inspected the two large fuses and they look fine, will reassemble fuses and battery first think, but I think I'm looking at the dreaded flat bed. Does any one know whether there is a separate 80A fuse just of the battery that supplies the relays fuses ecu etc etc? Matt.
Re: Help
Posted: Thu Feb 06, 2020 10:13 pm
by Shoppinit
Not many things that will cause a complete cut out without leaving a code.
Maybe crank position sensor.
Maybe x-relief relay or faulty ignition switch.
Re: Help
Posted: Thu Feb 06, 2020 10:29 pm
by Matt58
Thanks shopp, but can't use reader as no power to anything, are you aware of any 80A fuses directly off the battery that supply all the electronics? Cheers Matt.
Re: Help
Posted: Tue Feb 11, 2020 7:02 pm
by Matt58
Just a quike update, car flat bedded to Audi specialist in yeovil, hope its not to painful. Thanks for everyone's advice. Matt.
Re: Help
Posted: Tue Feb 11, 2020 9:06 pm
by Shoppinit
Hopefully it'll be something straightforward.
Re: Help
Posted: Tue Feb 11, 2020 11:31 pm
by Matt58
Shop, really hope so. Could of been a hell of a lot worse I suppose, imagine breaking down like that on a smart motorway at night, with no Lhasa rs lights, doesn't bear thinking about, will get a belt and braces job done I think. Matt.
Re: Help
Posted: Tue Feb 11, 2020 11:32 pm
by Matt58
That's meant to be hazard lights. Matt
Re: Help
Posted: Wed Feb 12, 2020 10:14 am
by Mɐʇʇ
There's not actually many things it could be - so shouldn't be too bad to find & fix.
Re: Help
Posted: Fri Feb 14, 2020 7:19 pm
by Matt58
Collected car today from RCMR in yeovil, owner explained that after gaining access to interior relay/distribution panel, found no 12v supply to interior of car. Load tested power cable to find high resistance. Found previous poor repair near to interior fuse under bonnet, partially removed cable and remove previous repair, repaired correctly, heat shrink and tape loom. In other words making good a previously butchered job. Thanks for all reassuring comments, glad it's all sorted and safe. Matt.
Re: Help
Posted: Fri Feb 14, 2020 10:21 pm
by Shoppinit
Phew.
