Headlight levelling fault
Hi guys
Cars just passed its MOT by the skin of it teeth because the headlights are not moving, now I’ve changed the sensor for a new one is there anything else to look for? Cheers
- simonpoulton
Re: Headlight levelling fault
Sensors... there is one at the front and back and they can fall off. Do you get any levelling errors show up on the matrix on the dash?
VCDS will show you the current values for each sensor - might be best to check in with that first.
Past: R56 Mini Cooper S
Only changed the front one as didn’t know there was one at the back all have a look at the weekend-thanks!simonpoulton wrote:Sensors... there is one at the front and back and they can fall off. Do you get any levelling errors show up on the matrix on the dash?
do all our cars have headlight levelling? or was it an option?
All cars with xenon headlights must have it by law in the EU.
south africa here, when I had my headlights out I didnt see any leveling mechanism
They would have all been the same, even for the SA market.
There is a linear stepper motor on the headlights that pushes a rod in and out to change the level. There are 2 lever type level sensors on the suspension, one front one rear. You can see a photo in the Bilstein installation FAQ.
It's possible that your car had aftermarket replacement headlights.
I seem to remember doing a thread about the headlights once. Maybe I posted some photos.
The stepper motor goes where the bottom left circle is.
I will take a closer look
- Top Gear
Had a fault show up on mine. Mine was at the rear. Lever/ball joint assembly.
Had been broken previously and owner had done a poor repair.
Replaced with new. No problems since.
should have updated this but mine are working fine.... never noticed them leveling before. I was parked on a slope with my lights on a garage door and when I started the car and had the lights on I could see them doing their thing.
murphys law.... I have never had an issue with mine... today I had 2 DIS faults
Users browsing this forum: Felix2566 and 93 guests
