Anything Else
Anything Else
OK, so soon, this'll all have been done, either now or historically, by me:
* Upper Lambdas
* EGTs
* Wagner ICs
* Alternator
* MAF sensors
* Plugs & Coils
* Injectors cleaned & flow tested
* SAI removal & coded out
* Gearbox
* Rear calipers
* Front Calipers
* Turbos
* Bufkin pipe
* DRC=>Koni
* Hotchkis ARB
* "Matt mod" oil cooler pipe
* Gearbox selector switch
Is there anything else on the "do it while it's in bits list"?
* Upper Lambdas
* EGTs
* Wagner ICs
* Alternator
* MAF sensors
* Plugs & Coils
* Gearbox
* Rear calipers
* Front Calipers
* Turbos
* Bufkin pipe
* DRC=>Koni
* Hotchkis ARB
- simonpoulton
Re: Anything Else
Few of these are engine out jobbies...
Brake lines (if corroded) - especially if you have the engine out as the offside runs through the steering rack chamber
Steering rack refurb?
Steering hydraulic fluid pipes (if corroded)
Starter motor
Oil pressure sensor
Water temp sensor
Solid water pipe round the back (replace the orings)
Timing chain guide/ pad thingys
Starter motor
Oil pressure sensor
Water temp sensor
Past: R56 Mini Cooper S
Re: Anything Else
Thanks. Reviewing:
Steering rack refurb? - do they have a life? Not massively up for spending 1K just in case if mine's likely to be OK for another decade.
Steering hydraulic fluid pipes (if corroded) - Yeah, good shout, I'll have a look.
Starter motor - How long do these normally last on these. There's no indication of the SM being worn, it cranks just fine.
Oil pressure sensor - Already done
Water temp sensor - will check, can't remember if I did that before or note.
Solid water pipe round the back (replace the orings) - Already done.
Timing chain guide/ pad thingys - Already done. Actually got a new water pipe on order which I'm gonna modify so I can easily get the RHS cover off for future fannying about.
Re: Anything Else
Where do you draw the line though, you could replace everything and have a fresh build but it’ll cost thousands.
Re: Anything Else
Totally. So lets say I don't mind pulling the motor every 5 years when I do the cambelt, since once the lock carrier is off, it's not much extra work.
And I do want mine to be one of the "good ones".
Re: Anything Else
Has the alternator ever been replaced? It's not a real crap job to do, but easier if it's all stripped down.
Re: Anything Else
Yup, I've done that already too..
Re: Anything Else
FWIW my steering rack just broke on me 10 days ago, so yes, such things happen.
Good news is that you can get them refurbished (ZF) at a very decent price :https://www.lizarte.com/en/POWER-STEERI ... -3075.aspx. Got it at 270€, to be installed next month (engine out).
Re: Anything Else
That’s almost brilliant except they only offer LHD
Re: Anything Else
Ha, why on earth would you want to drive on the wrong side of the road, buy a lefty!
- simonpoulton
Re: Anything Else
Left hand on the steering wheel and then your sword hand (right) is free to defend from attackers!
Re: Anything Else
Ha, makes sense now! lolsimonpoulton wrote: ↑Fri Oct 18, 2019 7:55 amLeft hand on the steering wheel and then your sword hand (right) is free to defend from attackers!
Re: Anything Else
All in bits and ready for powdercoating a few parts too:
