Page 1 of 2
Wheel spacer pics
Posted: Tue Oct 08, 2019 6:11 am
by Foxmeister
Does anybody have any pics of their car with 10mm spacers to see how it sits? Some angles would be good
Also, what spacers are best to use and where from?
Re: Wheel spacer pics
Posted: Wed Oct 09, 2019 5:33 am
by Foxmeister
Nobody??? Anybody???
Please, dont make me beg...
Posted: Wed Oct 09, 2019 11:01 am
by Shoppinit
Beg, biatch.
Posted: Wed Oct 09, 2019 1:06 pm
by chunky79
You could use the search function, there have been loads of pics put up on the C5 forum. Hopefully not all of them have been done over by photofucket
Posted: Wed Oct 09, 2019 4:09 pm
by Mark-RS
10mm H and R hubcentric.
I'll try and get a few pics......
Posted: Wed Oct 09, 2019 4:30 pm
by Mark-RS
A few that I was able to pull quickly.
Posted: Thu Oct 10, 2019 3:33 am
by Foxmeister
Shoppinit wrote: ↑Wed Oct 09, 2019 11:01 am
Beg, biatch.
Ok Mr Shopp... do i have to gargle also?
Posted: Thu Oct 10, 2019 3:39 am
by Foxmeister
chunky79 wrote: ↑Wed Oct 09, 2019 1:06 pm
Chunky, pretty much any forum search function is a load of pish so i never bothered with it, tried Pinterest, Google etc but theres a severe lack of decent C5 pics with info, we're being over run with these C7 beasts it seems, but i'll have a look
Posted: Thu Oct 10, 2019 3:53 am
by Foxmeister
Mark-RS wrote: ↑Wed Oct 09, 2019 4:09 pm
Well played sir
that looks great, and quite low, what suspension you got? Does it rub at all with the spacers?
From what i gather, 10mm is the max for the C5 but it looks like it could maybe do a bit more, wonder if 12mm would fit ok
Posted: Thu Oct 10, 2019 11:19 am
by chunky79
The search function on here had always been pretty good imo.
Think you may get some rubbing with 12mm, and possibly be outside the arches. Also got to be careful with wheel bolt length.
Posted: Thu Oct 10, 2019 12:41 pm
by Foxmeister
chunky79 wrote: ↑Thu Oct 10, 2019 11:19 am
Ok, i'll stick with the 10mm likely as they look fine and will just be a second set of wheels as i will be fitting the 20's soon
I did see something about the bolts, do you get replacement bolts with the spacers, no?
Posted: Thu Oct 10, 2019 1:08 pm
by chunky79
Not sure mate, I don't run spacers. Folk used to get them from Virdee, not sure of he still sells them.
Posted: Thu Oct 10, 2019 3:48 pm
by Mark-RS
H&R you get the bolts with them so no worries about that.
99% of the time I don't get rubbing. I do however get occasional rubs when hitting a dip in the road at speed but it appears to be more the lower edge of the wheel by the back door/sill area rather than the upper arch. Might be something to do with my camber set up.
I run KW V3 on mine, but have no idea of the settings. It was all done when I bought the car and I can see nothing in the paperwork with regard to settings other than... "Fitted"
Posted: Fri Oct 11, 2019 3:17 am
by Foxmeister
chunky79 wrote: ↑Thu Oct 10, 2019 1:08 pm
Cheers Chunk, i'll see what he says
Mark-RS wrote: ↑Thu Oct 10, 2019 3:48 pm
Nice one Mark, i had been looking at Eibach but i'll have a look at the H&R also
It looks good sitting low, just not sure if i can get away with it myself
Posted: Thu Oct 17, 2019 5:57 pm
by V!per
