Wiring diagram for Bose amp - PO hacked!
Posted: Tue Aug 20, 2019 8:50 pm
by E42
Hi, we’re fitting a Pioneer head unit and discovered when the RNS-D was removed that one of the POs has hacked the wiring about and removed the multi pin plug that connects to the amp and possibly other things too. So, we have a number of wires, some not even insulated, without knowing which to connect to the plug in the new harness adapter.
Can anyone help with a wiring diagram to ID which wire is which? I guess I also need a replacement connector to mate up to the new plug in the adapter harness?
Thanks,
Dom
Re: Wiring diagram for Bose amp - PO hacked!
Posted: Tue Aug 20, 2019 9:55 pm
by Shoppinit
Yeah. I can help. Remind me tomorrow.
Posted: Wed Aug 21, 2019 6:54 am
by MeTsU
Why on earth can people not just purchase an adapter - not only are they inexpensive, but make life so much easier.
Posted: Wed Aug 21, 2019 7:22 am
by E42
Hi, as I mentioned in the post we have the harness and adapter, there’s nothing to plug it in to, just a number of wires of various colours
Posted: Wed Aug 21, 2019 7:31 am
by E42
Shop, thanks for your offer, I’ve sent you a pm
Dom
Posted: Wed Aug 21, 2019 7:42 am
by Shoppinit
Pretty sure he was referring to the DPO.
Posted: Wed Aug 21, 2019 7:51 am
by Shoppinit
Is your intention to put the wiring back to standard? Or to wire to a plug specific to the new head unit?
Posted: Wed Aug 21, 2019 7:58 am
by Shoppinit
RNSDtoE.pdf
(186.89 KiB) Downloaded 55 times
I need to look up the individual wire colours.
Posted: Wed Aug 21, 2019 8:12 am
by E42
Thanks for your help with this. I’d aim to refit an oe spec plug to the loose wires, as per original spec then fit the new plug in the adapter kit to this?
Posted: Wed Aug 21, 2019 8:18 am
by Shoppinit
Sounds like a good plan. That's what I would do.
You can start by ordering the housings and pins (or repair wires if you don't have the crimping tools). What is your comfort level with wiring repairs?
Don't use chocolate blocks or Halfrauds type tube crimp connectors. Best thing is to solder and use heat shrink insulation.
Posted: Wed Aug 21, 2019 8:24 am
by E42
My comfort level is slightly above zero, but luckily the guy fitting the unit for me is very good, he was shocked at the state of the ‘modified’ loom! As you suggest, if you could help with an ID for the colours for the loose wires I can order the bits and we should be in business? Thanks for the pdf but I couldn’t read the diagram in your earlier reply?
Posted: Wed Aug 21, 2019 8:26 am
by Shoppinit
Try reading it again. It's just an image file. It's the part numbers you need.
Posted: Wed Aug 21, 2019 10:42 am
by Shoppinit
This is a after a quick look at the wiring diagrams. Accuracy not guaranteed and no responsibility accepted for anything!
Code: Select all
26 pin connector
1 brown / grey
2
3
4 black / blue (12v)
5 white / black
6
7
8
9
10
11
12 black
13 grey / white
14
15
16
17 blue / red
18
19
20
21
22
23
24
25
26 grey / red
8 pin connector III
1 white / green
2 grey
3 green / blue
4 red / black
5 red / yellow (0.35mm²)
6 grey / blue
7 red / yellow (2.5mm²)
8 brown
20 pin connector I
1 green
2 white (0.35mm²)
3 brown
4 grey
5 yellow
6 white (0.5mm²)
7 green (phone option)
8
9
10 brown (0.35mm²)
11
12 black (phone option)
13 orange
14 pink (?)
15 black
16 blue
17 yellow (0.22mm²)
18 shield (for 20 and 19)
19 white
20 red
Let me know if something doesn't seem right or you need more info.
Posted: Wed Aug 21, 2019 11:02 am
by E42
Brilliant, thanks for your help, much appreciated
Dom
