N/S Front diff leak
Posted: Fri Jul 26, 2019 12:50 pm
by Nobby
Noticed a slightly acrid smell coming from the car yesterday and turns out its diff oil leaking from the N/S.
Had a quick look in my workshop manual and it doesn't really cover what is needed to fix the leak. I've changed the CV boots god knows how many times, but how do you get the inner flange off? There is a cover plate which looks like it has 3 or 4 bolts holding it on. Do I need a puller or is there a centre bolt holding it on too?
Also heard mention somewhere else that there isn't a drain plug for it. Assume there is a filler though and fill up until it comes out.
Chris
Re: N/S Front diff leak
Posted: Fri Jul 26, 2019 3:11 pm
by Mark-RS
HAHA ! You said Flange !
Sorry I can't help with anything else
Posted: Fri Jul 26, 2019 3:37 pm
by Shoppinit
There’s one side that you can change the seal on in situ and the other which needs the box to come out, if I remember correctly. Been a while since I’ve looked at it. I’ll have another look to see if it sparks any recollection.
Posted: Fri Jul 26, 2019 4:44 pm
by Nobby
Found a vid on
YouTube for the ZF5HP24 (although it says 5HP24A in the description) gearbox and it looks like the flanges just unbolt. One side (think its my side) comes out with a shaft attached). The gearbox was removed from the car though.....
Posted: Fri Jul 26, 2019 4:45 pm
by Nobby
Shop I remember someone having a bad amount of axial play in one side of there diffs and the gearbox needed removing to fix. Hoping if its just the seal that not needed..... crossing fingers and toes....
Posted: Fri Jul 26, 2019 4:59 pm
by Nobby
Found a couple of threads
Leaking and play in the diff (mine doesn't seem to have any play though) -
viewtopic.php?f=2&t=106527&p=632180&hil ... ay#p632180
Mav was the one who had diff problems - his is the other side to mine though.
viewtopic.php?f=2&t=103961
Posted: Tue Jul 30, 2019 9:02 pm
by Nobby
Looks like i’ve found a mini guide to what’s needed (think from someone who has a phaeton).
https://forums.vwvortex.com/showthread. ... eplacement
I’ll do a bit of digging for part numbers and get it changed next week. I’ll stick some photos up when i’m done. Looks like i’ll need to get my hydraulic press out!
Chris
Posted: Wed Aug 07, 2019 9:05 am
by Nobby
Minor update: Ordered all the bits last week from my local TPS. Went to collect on monday and some parts are on back order.....
- including the main seal which I need. I'm gonna replace all the parts along that shaft (excluding the shaft itself), new hub bolt and some subframe bolts if I need to lower the subframe a little.
Guess I'll have to look at topping it up and do it properly next week. I found a few more videos of people taking apart the gearboxes in stages, but some are in French.
One thing I need to confirm - the front diff fill is on the the O/S (there's no drain plugs) and that is for BOTH sides of the differential. It looks like the shaft goes through a long tube which links it to the other side and that separates the gearbox oil from the differential oil. Can anyone confirm this please?
Posted: Wed Aug 07, 2019 9:44 am
by Shoppinit
Yup, there is only one fill hole for the front diff. I would expect the assembly to communicate since it's just a boggo diff.
Good luck with the job. If you can take some photos while you're doing it that could be helpful.
Posted: Wed Aug 07, 2019 9:58 am
by Shoppinit
It doesn't look like a fun job, but at least you might be able to get away with not dropping the subframe.
Make sure that you drain the diff oil before starting. It looks like if you pull the shaft out when it's full then it allows diff oil to spill into the ATF.
Posted: Fri Aug 09, 2019 9:50 am
by Nobby
All the bits have arrived! But I don't have time to change them now so it'll have to wait till next week.
Over £150!
Posted: Fri Aug 09, 2019 9:53 am
by Nobby
Shoppinit wrote: ↑Wed Aug 07, 2019 9:58 am
Are you sure Shopp? The O/S flange/shaft goes through a long tube which is pinned in place (and can't be removed unless you remove the gearbox as its staked from the bell housing side). I'm gonna drain it out anyway as I've never changed it. Assume as there's no drain its a vac pipe/syringe into the refill hole.
Posted: Fri Aug 09, 2019 10:26 am
by Shoppinit
Yeah, it says explicitly in the workshop manual that you'll get cross-contamination if you don't drain.
It's hard to tell looking at the exploded diagrams, but I don't see where the tube is fixed. There's a snap ring on the drive shaft side that suggests it's fixed at the outer end, rather than the inner end. Or maybe when you remove the bearing housing the o-ring doesn't make a good seal any more and allows oil to flow into the box.
It'll no doubt become obvious when you start pulling it apart, but I would err on the side of caution.
It's moot anyway if you intend to replace the diff oil. Yeah, you'll need to syringe it out. I don't think there's much in there. Maybe a litre max.
Posted: Wed Aug 28, 2019 2:18 pm
by Nobby
Well, the good news is its done!
I'll be writing up a how to shortly. In the meantime, I'll let you all guess how long it took me and leave you with an amusing story:
Draining oil isn't my favourite thing, especially when its gear oil which practically makes me gag. Even following the strictest procedures some oil always gets on the floor, so I mopped up what I could and lighly dusted the remaining patch with some cement dust. X hours later and all finished, I was in the shower getting rid of the stank and something odd has happened to my hair. I normally have styled wax in my hair. The excruciating bank holiday heat meant my head was pretty sweaty too, and ofcourse I'd been lying on the floor (with some protective mats though I might add). My head must have touched the cement though, and the mixture had dried into nice dreadlock clumps
It took a lot of washing to get it out!
I thought I might need to get the razor out
