low specified boost pressure (mbar)
Posted: Tue Jun 25, 2019 5:43 pm
hi. i have an '03 rs6. i recently sealed its intercoolers and repaired an unmetered air issue due to a cracked wastegate feed. my concern is the low "specificied boost" log printout i'm getting after 3rd and 4th gear turbo spools. specifically, the highest # i've seen is 1370 mbar (about 6 psi boost). 8 months ago i logged 1,700 mbar of specified boost (2,200 actual).
is this a result of the ECU starting to relearn after a 'clear codes' command? i don't have any faults and the n75 passes the 'click' test. should i pinch the return air pathway of the n75 to see if boost rises during a short drive?
i guess what i dont understand is what's driving the low specified boost numbers? the ecu? my fuel trims are less than 1.5% corrected. no misfires/knock. high grade gas. it does have an MTM ecu.
shouldn't i start to see 100% duty cycles over time and then see these numbers fall to correct for high actual boost numbers?
also,where specifically is the specified boost being measured? the two air mass sensors? thanks in advance.
