Exhaust blow
Exhaust blow
Not had much time with the RS but recently when starting from cold, and wanting to load the ultra modern 6 disc changer in the boot, I was hovering around the passenger side to access the glove box and noticed what sounded like a bit of an exhaust blow from the area, never heard from drivers side and only audible from cold start for a couple mins really, is there a common issue here and should I prepare to lube up and bend over???
Or is it a case of getting under and having a nose about really?
Re: Exhaust blow
Always use lube!! I didn’t before I started this engine pull and now I’m going though a tube of cream to keep the pain at bay....Foxmeister wrote:Not had much time with the RS but recently when starting from cold, and wanting to load the ultra modern 6 disc changer in the boot, I was hovering around the passenger side to access the glove box and noticed what sounded like a bit of an exhaust blow from the area, never heard from drivers side and only audible from cold start for a couple mins really, is there a common issue here and should I prepare to lube up and bend over???
Re: Exhaust blow
Could just be the SAI doing its thing. Sounds like a blowing exhaust for a while.
Re: Exhaust blow
Quite possibly. Alternatively the sleeves and jubilee clamps between the down pipes and the exhaust might need a little tweak. I had the same issue on mine some time back and just needed to readjust them and used a little firegum too.
Re: Exhaust blow
Cracked manifolds happen! Here’s hoping it’s not that
Re: Exhaust blow
You'd hear (and smell) that with the bonnet open. I had exact symptoms the OP noted, sound cam from under the car in the vicinity of the front footwells nad it was just the joint.
Most jobs on these cars are a £1000 hit, but not absolutely all of them.
Re: Exhaust blow
Really? Interesting and would explain why I've never noticed it before, hopefully it's nothing serious then
This would be obvious if under the bonnet then, might try a cold start next time with it open to investigate
Re: Exhaust blow
Hoping it's something this simple Matt, as a Milltek will no doubt find it's way on there soon anyway then it's a case of 2 birds one stone
Cars done 87K so hoping it's not manifolds gone, that would be a proper kick in the balls
Users browsing this forum: anditsoundslikebells, srichards and 122 guests
