Any one got a labeled pic if the engine loom.
Puggie
Post by Puggie » Tue Mar 19, 2019 6:31 pm
So about 2 years ago I took the loom off and engine out, now a newer engine is back in I really regret not labeling it all up properly (I really mean at all). Any one got a good set of pics of where everything goes under the air box. A good chunk is plug and play, but there are a lot of generic 2 and 3 pin sensor connectors in there.
Cheers for any help.
Comments along the lines of 'you tit you should have marked if up before pulling it' will not help, I know that already!
Jayjay101
Re: Any one got a labeled pic if the engine loom.
Post by Jayjay101 » Tue Mar 19, 2019 6:44 pm
:knob: but ive done worse!!!! ha!ha!
but to be honest a lot of it you cant get wrong as they will only fit one type of connector anyway-i never marked any of it up when i did mine apart from the coil pack wires
Lennart.
Post by Lennart. » Tue Mar 19, 2019 11:00 pm
I have done this work a few weeks ago, i still have the pictures. I can try to upload them tomorrow.
Nobby
Post by Nobby » Wed Mar 20, 2019 1:21 pm
Not got a photo myself, but isn't there one good photo of the engine with the airbox removed showing N75, MAF, DV etc locations. Might give you an idea on where the wires go generally. NB: Space is quite tight, and I've found that if they aren't neatly arranged you could have problems locating the carbon airbox as the loom fits in slots underneath it.
Daytona RS6 Avant
