Cylinder head pull....
Posted: Fri Feb 01, 2019 5:16 pm
by Jayjay101
Hi guys
Right so after doing a compression test cylinder 6 is really low(30psi) so looks like when the cam chain pad broke it jumped a tooth and there’s valve damage-so I’m going to take it I have to pull the engine to get it off or can I get it off with the engine still in?? Cheers
Re: Cylinder head pull....
Posted: Fri Feb 01, 2019 5:39 pm
by Nobby
Before you do that i’d suggest popping a little oil into cylinder 6 (via the spark plug hole) and doing the test again. If the reading goes up drastically then it’ll be a piston ring problem. If not then valves.
Normally i’d say heads can be taken off with engine in situ but manifolds and inlet need to come off. Manifolds to turbo are pretty far back to get access to. You may be able drop the subframe at the back to get downpipe and turbo for that side off but it’d be easier with engine out.
Posted: Fri Feb 01, 2019 6:03 pm
by Mɐʇʇ
Feck! Bad luck.
The only thing I would say is that I think you'd be really pushing your luck to do it engine in - there comes a point where pulling the engine takes more time up front - but makes every other job easier after that and enables you to also do all the extra little cleanup/fettling jobs at the same time. I wouldn't enjoy pulling my motor again, but I would sooner just crack on and get it done rather than wrestling with every last thing. It's not hard to pull the motor - there's just quite a lot of things to do. Some good tunes, a bit of heat in the garage, a couple of packs of hob-nobs and job done.
Posted: Sat Feb 02, 2019 12:16 pm
by R5XVB
If you need it, I have a BCY top half for sale listed on eBay.
Posted: Sat Feb 02, 2019 2:52 pm
by 95ninety
The same thing happened to my car.
Unless you are an octopus, the motor must come out.
Posted: Mon Feb 04, 2019 1:02 pm
by PipRS6
30psi is a bit low to be worn piston rings. Only catastrophic ring failure could cause it and then oil wont change the reading.
I think you are right in your assumption of valves. Especially if timing is known to have jumped. If you rebuild the head then make sure you get the head pressure tested. A bent valve could also have cracked the head slightly.
Posted: Mon Feb 04, 2019 1:40 pm
by Shoppinit
This sounds like a fortuitous coincidence. I'd be jumping on it.
Posted: Tue Feb 12, 2019 9:26 pm
by R5XVB
Wish he would, I’m tripping over it... :biggrin2:
Posted: Tue Feb 12, 2019 9:47 pm
by Mɐʇʇ
:biggrin3:
