Page 1 of 2
Let's talk timing belts
Posted: Mon Jan 14, 2019 5:10 pm
by jolio1994
So, I'm gearing up to do the valve cover gaskets and oil cooler coolant pipe very soon. Figured, why not do the timing belt as well.
As we're all aware, the timing belt is recommended to be serviced every 35,000 miles. ECS Tuning sells a complete timing belt kit with the Blue Gates Belt (300% Stronger). I've used them for all my previous 2.2T and 2.7T applications and they are made from a harder material for sure. With that said, would it be safe to assume I could run it until the normal 70,000 interval or are there other components such as the tensionor, waterpump, or thermostat that would fail in between 35,000 - 70,000 miles?
Link to timing belt kit: https://www.ecstuning.com/b-assembled-b ... 09119jkt4/
Re: Let's talk timing belts
Posted: Mon Jan 14, 2019 5:23 pm
by Jayjay101
Think most of us in here only use oem Audi belts and tensioners(even the guys running more power)and I have herd of these gates belts snapping-the Audi belt is more than beefy enff for the job on its own.as for doubling the mileage between cambelt changes more power to you if you do that!! I wouldn’t
Posted: Tue Jan 15, 2019 10:49 am
by Daveperc
The belt change interval was 40,000 initially and was then upped by Audi to 60,000 miles.
I wouldn't mess with an alternative personally
Posted: Tue Jan 15, 2019 11:11 am
by jolio1994
Sounds good to me. I'll keep it OEM. I've seen intervals all over the place. With the new technology and material's belts are made of nowadays, is 60,000 safe to go off of?
Posted: Tue Jan 15, 2019 11:29 am
by Shoppinit
Probably time period is more relevant these days. Not many people doing lots of miles in RS6s.
Posted: Tue Jan 15, 2019 5:47 pm
by Ben_r1
Nothing wrong with Gates timing belts, they provide OE belts to many manufactures and in the Evo scene are recommended over OE.
Dayco are also highly regarded and OE suppliers.
I’ve used both brands over the years on many applications from mileage munching daily’s to dedicates track toys with no issues.
Most failures probably come from poor/incorrect installations.
Posted: Thu Jan 17, 2019 3:04 pm
by 95ninety
Do you have a source for that info? TSB or the like? Thanks
Posted: Thu Jan 17, 2019 3:07 pm
by Jayjay101
There’s a sticky on here for it all
Posted: Thu Jan 17, 2019 7:41 pm
by 95ninety
Where? It is not in the sticky at the top of this forum.
Posted: Sat Jan 19, 2019 10:32 pm
by bilko1
viewtopic.php?f=2&t=90358 1/4 way down the page.
Posted: Sun Jan 20, 2019 3:25 pm
by 95ninety
Thanks, but I'm looking for proof that Audi changed the belt interval to 60k miles. Would be nice if true.
Posted: Sun Jan 20, 2019 3:53 pm
by Shoppinit
I've got a copy of a letter from Audi UK stating the timing belt interval is 57k or 4 years whichever sooner.
/Not that I'd necessarily but a lot of stock in what they say.
Posted: Mon Jan 21, 2019 5:39 pm
by 95ninety
Can you post the letter?
Posted: Mon Jan 21, 2019 5:44 pm
by Shoppinit
Meh. Not publicly.
Posted: Mon Jan 21, 2019 6:00 pm
by Daveperc
From what I remember (it was about 10 years ago!) various people rang Audi and got confirmation. They said they would do a memo round the dealers to confirm but I have no idea if they ever did as mine came out of warranty soon after and I switched to having such work done by MRC.
Why not give Audi a ring and ask.
