Engine noise.....
Engine noise.....
https://www.youtube.com/watch?v=y7xN9Xs ... ture=share
Hi guys-So I’m at my wits end with this now I thought it was the power steering pump but I removed the aux belt and run the engine and it still making the same noise also I’ve stripped down the front of the car to see if anything is rubbing on the cambelt and nothing-could it be cam chains?? Sounds like sheet metal rubbing on a pully? Any ideas?? Thanks jay
Re: Engine noise.....
Gearbox ATF pump cavitation? You got the right strainer on it? The one with the short pickup pipe?
I’m not sure mate as I had someone else service the box last year-it’s never done it before-the sump on it is pushed up a bit but it’s been like that from the day I’ve had it-it’s started from the day I put the engine back in-you think the the sump has moved even more from sitting on the pallet when I had the engine out??Shoppinit wrote:Gearbox ATF pump cavitation? You got the right strainer on it? The one with the short pickup pipe?
It’s a possibility. Cavitation sounds a lot like belt noise.
Does it do that from a cold start ??
I had same noise with the gearbox pump - after about 5 min of starting cold it was producing exactly same noise. A quick service - oil and filter - and it was all back to normal.
Yes mate! Think what I’ll do is change the filter and the sump pan for my other one that’s not had a wack and see what happens-seeing as you and Shop have both said the same thing can’t be far wrongV!per wrote:Does it do that from a cold start ??
here is the video of mine
https://youtu.be/wIIXjNofiJI
Guys actually thought the new hybrid turbos just gave up on the dyno runs
The extra gearbox service certainly won't do any harm and hopefully will resolve your problem. Be wary of driving it before sorting this because the actuators will be starved of ATF and could accelerate clutch wear.
Get the strainer from TPS / Audi. The ATF, too. You'll need a new gasket, too.
Shoppinit wrote:The extra gearbox service certainly won't do any harm and hopefully will resolve your problem. Be wary of driving it before sorting this because the actuators will be starved of ATF and could accelerate clutch wear.
I’ll pull the pan and see what the part number is on it because isn’t there 2 types?
It’s up on axle stands with the front off at the moment as I’m just about to fit meth when I solve this problem
Thanks again for the info chaps!
Yeah, but it might be the wrong part. They are frequently confused with the generic 5HP24 type strainer which has a longer pick-up pipe. You need the RS6 specific strainer.
Do you have the part number to hand? Or is it on the diy How too?Shoppinit wrote:Yeah, but it might be the wrong part. They are frequently confused with the generic 5HP24 type strainer which has a longer pick-up pipe. You need the RS6 specific strainer.
This is what I bought to do mine: 01L 325 429 B
£45 full whack price.
Shoppinit wrote:This is what I bought to do mine: 01L 325 429 B
£30 for the gasket and £55 for the filter now Shop and £14 a litre for the atf
That’s a worthless pound for you.
Just pulled the sump in the box and this is how dented it isShoppinit wrote:That’s a worthless pound for you.
Fluid still really clear and little bit of furryness on the magnets-the o-ring seal of the filter was crap as soon as I unscrewed it it just fell off
Users browsing this forum: 03slatt, anditsoundslikebells, Felix2566, Shoppinit and 201 guests
