Folks I’m just about to order a set of 4 x upper arms...
The listing shows them for the RS6 C5 BCY engine.
Only bit that made me ask a question before buying is that it says they are for the “saloon”.
Can someone confirm that the saloon and Avant share the same components?
Many thanks
Ben
Lemforder front upper arms
Re: Lemforder front upper arms
Anyone?
Bueller?
Pretty sure they are the same part. If in doubt, use the parts catalogue in the FAQ to check the part numbers for the saloon and Avant.
Check on here. Compare the part numbers between the saloon and avant...
https://audi.7zap.com/en/rdw/
PipRS6 wrote: ↑Mon Sep 17, 2018 1:06 pmCheck on here. Compare the part numbers between the saloon and avant...
I’ve had a good look and I believe that link only covers the avant model, unless of course it is for saloon/avant on the same page?
Can anyone else confirm this?
Ben
Covers both. I double checked by going in to body work and looking at the boot assembly (rear lid I think they called it). There are separate sections marked as Saloon and Avant.benh999 wrote: ↑Tue Sep 18, 2018 7:39 amPipRS6 wrote: ↑Mon Sep 17, 2018 1:06 pmCheck on here. Compare the part numbers between the saloon and avant...
Ben
Perfect, I’ll get them orderedPipRS6 wrote: ↑Tue Sep 18, 2018 9:01 amCovers both. I double checked by going in to body work and looking at the boot assembly (rear lid I think they called it). There are separate sections marked as Saloon and Avant.benh999 wrote: ↑Tue Sep 18, 2018 7:39 amPipRS6 wrote: ↑Mon Sep 17, 2018 1:06 pmCheck on here. Compare the part numbers between the saloon and avant...
Ben
Users browsing this forum: javier_gl, Marcin, Shoppinit, srichards, steve2003rs6 and 200 guests
