F125 Switch
- 2nd Gear
F125 Switch
After a long and tedious diagnostic with much help from the guys on this forum which I greatly appreciate I think the issue I have with my gearbox is the F125 switch as when I start the engine the gear selector indicator goes straight block out all options in red and eventually after moving car or trying various things I can get the car to select a single gear option. I contacted Audi for the cost and availability of a spare switch but was quoted £200 plus Vat so can anyone recommend someone who can supply discounted OEM parts if such a company or person exists?
Look forward to hopefully get some good contacts
Re: F125 Switch
I think companies like TPS can supply them too, but pricing is pretty consistent.
There are 2 versions, an 8-pin and 10-pin connector, with somewhat different prices.
My S8 needed the later 10-pin version, but that was still well over £150; the earlier 8-pin costs more.
Re: F125 Switch
You might find an alibaba special, but be prepared to replace it again a few months later.
Re: F125 Switch
I personally wouldn't touch those with a bargepole!
Maybe the RS6 is easier, but for an S8 there's a lot of work involved so I'd only ever get OEM
Re: F125 Switch
That was kinda my point.
Re: F125 Switch
genuine sensor grind small part of alloy off the gearbox mount and swap switch out takes about 1hr tops
#VAGDoctor
- 2nd Gear
Re: F125 Switch
Thanks for your comments guys, as I stated, no intention of using cheap eBay Chinese copy will only fit genuine Audi part but hoped someone may know somewhere that would offer discount of genuine Audi parts
Re: F125 Switch
Good luck with that, but don't get your hopes up.RS6Rottweiler wrote: ↑Thu Sep 13, 2018 9:26 amhoped someone may know somewhere that would offer discount of genuine Audi parts
In the D2 A8/S8 community replacing the F125 switch is a sadly common (and bloody difficult!) activity, no-one there has ever mentioned a good source of genuine parts at a discount.
Users browsing this forum: 03slatt, Felix2566, MeTsU, Shoppinit, steve2003rs6 and 227 guests
