Page 1 of 2
Radio and Lights Issue
Posted: Thu Jul 12, 2018 11:35 am
by EireRS6
Hello there,
I have an issue at the moment where my radio won't turn off when I remove the key so I have to switch it off on the button each time I turn the car off.
Also, if I turn the car off leaving the lights on, there is no beep or warning sound. I'm assuming there should be?
Can anyone help with the above? Are the issues linked in any way?
Re: Radio and Lights Issue
Posted: Thu Jul 12, 2018 11:36 am
by Shoppinit
Sounds like the key-in switch is borked on your ignition switch.
Posted: Thu Jul 12, 2018 11:42 am
by MeTsU
Odd question, but if you accidentally leave your handbrake up, does the car beep at you? Come to think of it, I'm not sure if the handbrake uses the same buzzer or not.
Posted: Thu Jul 12, 2018 11:50 am
by EireRS6
Shoppinit wrote: ↑Thu Jul 12, 2018 11:36 am
So I just need to replace the ignition switch?
by EireRS6
MeTsU wrote: ↑Thu Jul 12, 2018 11:42 am
No, I've never noticed this happen.
Posted: Thu Jul 12, 2018 11:53 am
by Shoppinit
You can probably test it with the
Vagcom.
Posted: Thu Jul 12, 2018 11:54 am
by EireRS6
Ok. One really needs to have
Vagcom with these machines!
Posted: Thu Jul 12, 2018 12:12 pm
by Shoppinit
It's the first tool any owner should buy.
Posted: Thu Jul 12, 2018 1:03 pm
by EireRS6
Do they ever come up for sale on here?
Seems to be loads of types available. Is there any you would recommend?
Posted: Thu Jul 12, 2018 1:07 pm
by MeTsU
I have the 2017 version of the
VCDS cable which is unlimited VINs. Reference to
https://store.ross-tech.com/shop/vchv2_ent/
I'm not sure who the Distributors are in the UK, but locally in ZA,
https://shop.hexdiagnostics.co.za/produ ... 2amqk21c63 is what I have.
Posted: Thu Jul 12, 2018 1:12 pm
by EireRS6
Thanks MeTsU.
Posted: Thu Jul 12, 2018 1:26 pm
by Shoppinit
Try ilexa.co.uk or Gendan.
My OCD means I must own unlimited versions. :-/
Posted: Thu Jul 12, 2018 2:36 pm
by EireRS6
There looks to be a 3 VIN from Gendan for £225.
Posted: Thu Jul 12, 2018 4:25 pm
by Mark-RS
My cheap eBay cable works just fine
Posted: Thu Jul 12, 2018 5:10 pm
by Mɐʇʇ
Well, 2nd. First is an extra large pot of vaseline.
Shoppinit wrote: ↑Thu Jul 12, 2018 12:12 pm
