Page 1 of 2
Dropping the gearbox out
Posted: Sun Jun 17, 2018 7:01 pm
by Gavinda
In the process of swapping to an 01e 6speed. Just looking for a bit of advice on certain parts of the swap.
Does the box come off with the turbos in place? Managed to get both the downpipes off and all the bellhousing bolts including the top two :rocker:
but something is stopping the box from sliding off. torque convertor backing plate bolts are off , do i need to do something else with torque conv back plate?
Re: Dropping the gearbox out
Posted: Sun Jun 17, 2018 7:40 pm
by bam_bam
Usually have to drop the engine with the box.
Posted: Sun Jun 17, 2018 7:52 pm
by Gavinda
Ive dropped the engine down a bit, but i was hoping not to take the whole lot out . Subframe is off ofcourse.
Posted: Sun Jun 17, 2018 7:56 pm
by benh999
Apparently that gearbox chap in London drops the box with engine in situ?
Posted: Sun Jun 17, 2018 7:59 pm
by Shoppinit
It's possible. When I went to 512 trans they told me that no one had told them that the box had to be removed with the engine so they just removed the box.
Posted: Sun Jun 17, 2018 8:10 pm
by bam_bam
So there we have it, use the gearbox chap in London or 517 trans...
Posted: Sun Jun 17, 2018 8:14 pm
by Gavinda
lol
Posted: Mon Jun 18, 2018 7:51 am
by bilko1
Have you undone the torque converter to drive plate bolts?
Posted: Mon Jun 18, 2018 11:00 am
by Gavinda
Yes, taken those bolts out , accessed from the starter hole,. Think gearbox is just being a bit awkward, gonna change angles slightly and see if its just a bit of weight holding the torque convertor into the end of the crank.
Posted: Mon Jun 18, 2018 1:21 pm
by benh999
Is this all being done off stands or have you access to a ramp?
Posted: Mon Jun 18, 2018 6:39 pm
by Mɐʇʇ
Most important, IIRC. Keep the TC on the box. The mistake I made the 1st time was as I pulled the box off, the TC came half off the gearbox too. TC must stay 100% home on the gearbox input shaft, then you don't need to remove turbos. (I think, it was a while ago)
Posted: Mon Jun 18, 2018 9:02 pm
by Gavinda
On stands , but is over the pit. Engine is held on a brace bar. Gearbox being supported by a gearbox jack( tall jack with cradle) front subframe is off.
Posted: Tue Jun 19, 2018 4:36 pm
by Ben_r1
Looking at it I would have thought it’d be easier just to remove the engine and box complete, seen this done on someone’s driveway before with relative ease.
Posted: Tue Jun 19, 2018 4:41 pm
by PipRS6
Possibly a stupid question but if the car is over a pit what is the jack standing on?
Posted: Tue Jun 19, 2018 5:37 pm
by benh999
Bottom of the pit I’d guess
