Xenon range fault
Xenon range fault
I did my cambelt last week and a full service , however since then I seem too acquired a range control fault .I've plugged it in to VCDS, but I can't seem to get into the range control to see what the fault is . Am I missing a trick here ? . I lve checked the fuse and wiring too and around the lamps, all seems ok . Any ideas would be very welcome . Cheers Al
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
Re: Xenon range fault
Module 55 IIRC.
Connect to it and use the measuring blocks to test the voltage coming back from the 2 level sensors.
If you can't connect you might have a dead module (unlikely) or wiring problem.
Cheers Ben, I'll go and plug it in now . Just seems odd that it's always been fine . Since having the car in the air I have the orange light fault on the dash and the beams don't dip and come back up when switching them on .
Cheers Al
Hmmmmmm, I'm just getting an error message saying 'no response from controller ' .
Cheers Al
Can you connect to other modules ok?
Yeah , I can get into everything else that I tried ( other than stuff I assume isn't on the car that is ) .
Cheers Al
Users browsing this forum: steve2003rs6, Sxcarmyboi and 161 guests
