Hi everyone,
So the previous of the RS cut wiring to install an aftermarket radio, instead of using an adapter. My RS came with the RNS-E and Bose setup - not sure what other information one might require.
Is there anyone who possibly could share the exact wiring colour to pin, either via text or photos? I haven't been successful in decoding the information from our "resource centre". Also, nearly all of the info I've been able to find has been related around retrofitting the RNS-E to replace a RNS-D for e.g.
I would greatly appreciate it and would share some virtual with anyone that could help. I was able to find the following from an eBay sale - it might help a little bit:
Thanks, Matteo.
RNS-E with Bose Wiring
2004 Audi RS6 Avant Plus #283
Re: RNS-E with Bose Wiring
I had a quick look at the electrical diagrams. All the connections and wire colours seem to be on there. If you need the part numbers for the connectors and pins, try here:
http://www.vaglinks.com/Docs/Catalogues ... dipins.pdf
Thanks Shoppinit, I think we should be good on the connectors and pins, I ordered some repair wires to be used if necessary.Shoppinit wrote:I had a quick look at the electrical diagrams. All the connections and wire colours seem to be on there. If you need the part numbers for the connectors and pins, try here:
I think I'm concerned that I'm not getting the right view of the electrical diagrams. Will PM you.
Users browsing this forum: c4v8 and 386 guests
