Need New Engine
Re: Need New Engine
Barely run in
Re: Need New Engine
Viper,
Good luck with the fix.
Hope to see you back on the road soon.
Fancy comming to Le Mans ? We have a spare place availiable.
see
viewtopic.php?f=65&t=128167
Ric
see
Ric
Re: Need New Engine
Capt Ric wrote: ↑Wed Apr 11, 2018 11:59 amViper,
see
Ric
Oh Man - I wish. especially it fall on my birth day
But if I get the car up and running I will be VEEEERY light on cash unfortunately
Re: Need New Engine
I've gone through a motor, when pulled to swap for another oil pump was seized solid... same thing going down a bypass and let go sized first 4 con rods nearest the oil pump! I've priced up building the old one even with a second hand crank it's 2+k in parts
Re: Need New Engine
So
Got the turbos done.
Wagners on,
Got redesigned oil cooler and hoses - pic. Should get the oil temp in check
The new(2nd hand) RS6 Plus engine was tweaked already - ported intakes plus couple other bits already done on the engine.
Engine tuning should begin this week - subject to the engine running properly
Wagners on,
Re: Need New Engine
Interesting. I wouldn't have thought of mounting them like that - but it looks good.
Re: Need New Engine
Hopefully it won't take too much cooling away from the main rad. My gut feeling is that it will be OK as long as you don't go to Saudi Arabia.
Re: Need New Engine
Is that one cooler for the engine and one for the 'box?
Re: Need New Engine - Build updates
I am planning to modify the bonnet slightly - do a Bentley Continental style vents
Yes
They are - they are two separate coolers just mounted like that
Re: Need New Engine
IMO, those vents look nasty. Even on the Bentley.
Re: Need New Engine
Re: Need New Engine
What’s the pressure drop on those coolers over OE? They look massive!
Re: Need New Engine
That's a good point. Also without heat exchange with the coolant, I'd be a bit concerned about over-cooling the oil.
Users browsing this forum: No registered users and 198 guests
