Page 1 of 2
Battery replacement.
Posted: Tue Jan 16, 2018 8:49 pm
by benh999
My RS has been sat since Oct and the battery is flat as a pancake..
Put her on charge however it doesn’t seem to be charging to full. My charger will charge up battery and then switch to maintenance mode and this is not happening so I’m assuming the battery is possibly on it’s way, so........
What batteries are proven to be good and well priced..
Links/thoughts?
Ben
Re: Battery replacement.
Posted: Tue Jan 16, 2018 8:55 pm
by mavada
Battery
110Ah
Varta VA0 DE 000 915 105 AK
Dimensions: 394mm long, 175mm wide, 190mm high.
Posted: Tue Jan 16, 2018 9:12 pm
by Steveo
I replaced mine about a year ago. I had the Varta one but I couldn't get hold of another one at the time. So I bought a Bosch one instead. The two batteries are identical!
I'll try and get a picture of the Bosch one tomorrow if it stops raining for long enough
Posted: Tue Jan 16, 2018 10:53 pm
by Shoppinit
Those big batteries can take a long time to charge. Varta FTW.
Posted: Tue Jan 16, 2018 10:54 pm
by dch1n
Got mine from Tanya batteries for £125 last year.
610 200 Varta Silver Dynamic Car Battery 12V 110Ah 020 (Short Code: I1) (Varta DIN: 610 402 092 )
Does the job just fine.
Dan
https://www.tayna.co.uk/Varta-VW-1J0-91 ... P9383.html
Sent from my Pixel using Tapatalk
Posted: Wed Jan 17, 2018 8:52 am
by Ben_r1
I usually just use a Halfords battery, good savings with a trade card and 5 year warranty can’t go wrong
Posted: Wed Jan 17, 2018 9:04 am
by Shoppinit
Good luck trying to use that warranty, though. They always wriggle out.
I've had unbranded, cheapo batteries that have lasted for 10+ years and I've had known brand batteries that have hari-kari'd after 4 years. Seems to be pot luck. Once the battery in my Golf 2 exploded and the acid stripped all the paint off the battery tray and engine bay around it.
I think it was a Bosch.
Posted: Wed Jan 17, 2018 1:11 pm
by benh999
Shoppinit wrote: ↑Tue Jan 16, 2018 10:53 pm
How long ish?(from flat)
Posted: Wed Jan 17, 2018 2:05 pm
by Shoppinit
With a 110Ah battery and a feeble charger, could take as long as 3 days.
Posted: Wed Jan 17, 2018 2:06 pm
by Shoppinit
I recently charged some 180Ah marine batteries from flat and that took about 5 days.
Posted: Wed Jan 17, 2018 2:11 pm
by Steveo
I had my Varta one on charge for over 36hrs on an old and fairly basic Halfords charger. But it has done the job fine. It'
Posted: Wed Jan 17, 2018 3:33 pm
by benh999
Aha.. I’ll keep charging then I’d say this had been on for 18rs. I just assumed it would have trickle charged by then?
Posted: Wed Jan 17, 2018 3:50 pm
by Shoppinit
Simplistically: Most domestic chargers are less than 4A max charging current. Also the current tapers off as the battery charges. So say on average 1.8A over the charging cycle. Assuming 70% charging efficiency to charge a 110Ah battery (assuming full capacity) then it'll take approximately 3.7 days. Maths, innit.
Posted: Thu Jan 18, 2018 1:47 pm
by Ben_r1
Shoppinit wrote: ↑Wed Jan 17, 2018 9:04 am
Swapped a few myself, never had that much f a problem. They email you the receipt now too.
Posted: Thu Jan 18, 2018 1:49 pm
by benh999
She’s charged... green light for Maintenance mode, CheersShoppinit
