replace upgrader our dear N75 by a model strengthen type MAC boost controller?
hello to all I come back you break the candies ^ 0 my N75 of my rs6 c5 starts again to give signs of fatigue I had it replaced by a second hand that I had on hand,
my question can we replace it with a model like this
https://store.034motorsport.com/boost-c ... olled.html
Are some of you already replacing theirs?
reliability returns? mine is already in training 1
thank you in advance for your feedback, printing
Re: replace upgrader our dear N75 by a model strengthen type MAC boost controller?
Linky no worky.
I don't like the bit that says it will require custom tuning...
its me gene too I will like a valve oem which replaces the n75b without modification of the cartography
I think you're screwed. They're not *that* unreliable. Just get a couple from Audi to leave on the shelf.
http://www.topendpower.pl/p/en/mac-esbc ... valve.html
ou un modele comme celui ci
you mean it's better the original one I did not really understand
Might be worth a try. It's not expensive. Let us know how you get on.
it's order the solenoid a 1/8 elbow and a male plug ev1 story to do clean work I will post photo and felt goes up
Envoyé de mon FRD-L09 en utilisant Tapatalk
Cool. Let us know how it goes.
What are the symptoms of a dodgy n75?
My car feels a bit ‘wooly’, not quite as sharp as it should. Was wondering if changing this would help, or the MAFs?
MM
MM
2017 RS6 PE Nogaro
The N75 is opening and closing to regulate your boost, controlled by the ECU. So if it's not working properly you'll get either less boost than you should or more, or both.
You won't get a code for underboost, but you will for overboost.
Thanks Shop. It is an underboost feeling, though sometimes at Wot in higher gears boost cuts like you’ve hit the Rev limiter.
No warning light though.
2017 RS6 PE Nogaro
Could be N75. Could be DVs. Could be lots of things.
You need to log stuff with the Vagcom to figure it out.
Users browsing this forum: Marcin, Shoppinit, srichards, steve2003rs6 and 211 guests
