rs6 c5 power loss and supercharging circuit leaks
Re: rs6 c5 power loss and supercharging circuit leaks
Obviously the turbos on the RS6 don't have variable geometry, but what is interesting is that the ECU is asking for less pressure for no apparent reason and no sensor reporting a problem.
Might be worth replacing the charge pressure sensor, but I would expect it to throw a fault if you were over-boosting.
Perhaps log the EGT values? Coolant temp, too. I'm struggling to think of what would cause the car to ask for less pressure that wouldn't also throw a fault code.
it has to work remapping that's why it's weird,
it is a preparator 500cv 650/660 nm he did not charge either
my coolant sensor is new it was 1/2 defective, for egt what channel?
I will try to put back the DV of origin by acquired conscience I buy it on ebay possible that it is badly tarte or defaillante
I go back the original DV the new was much harder and was squarely blocked which explains the gap MAF but still no pressure sensor G31 may generate a kind of breakdown?
That's with the engine stopped?
Yes engine stopped it's normaly?
Envoyé de mon FRD-L09 en utilisant Tapatalk
That's baffling. Why would it ask for boost with the engine off?!
I think there might be something wrong with your map. Can you put it back to standard to see if it improves?
it is the boost specified not the current so possible that it is asked by pressing the pedal fully even when stopped, about that which determines the boost specified cartography, calculator, sensor or other? for mapping I recontact the preparer to have the original file and reset it to compare
I must admit that I've never tried it on mine. Maybe it's normal. I will try it when I can, but won't be able to for a couple of weeks. Anyone else want to give it a try? (engine off, press accelerator pedal fully to see what requested boost is.)
Let's see what happens when you put the map back to standard.
I will see with a friend who has one to do the same test, yes original I will compare
Any progress?
Hi everyone I did not have too much free time I'm going to seriously attack the engine after 6/05
hi with the ferie may I enjoy to get out the monster chassis not too bad output
the leaks come from the rocker cover joints and missing screws on the bottom motor probably loose because of the vibrations I will take the opportunity to make the cleanliness and change the maximum seal and aac tensioner pad
Users browsing this forum: BarringtonStanley, javier_gl, Shoppinit, steve2003rs6 and 154 guests
