rs6 c5 power loss and supercharging circuit leaks
Re: rs6 c5 power loss and supercharging circuit leaks
I mean the valves where the air is injected into the exhaust stream (using the N112). They can leak and cause vacuum problems.
Yes, those are the misfire counters I mean.
markers 10 and 11 is it?
on a French forum people had tendencies to say that if the secondary air system was failing it did not entail a loss of power but a cause of pollution mainly
Yes, 10 and 11.
If the SAI combined valve fails it can leak vacuum (bad) or introduce air into the exhaust (very bad - screws up the lamda regulation). Look at Gav66's thread about power loss due to leaking SAI.
If the SAI pump fails, then it's not so serious. But that will give a code. The others won't necessarily.
nice for the post, in his case it was used user hoses I replaced everything in reinforced silicone I read that with the heat they are altered
N249 received I ride it tomorrow by crossing my fingers this is his
That would be good. Fingers crossed.
Did you say you already changed the DVs?
yes DV's are new they must be 5 or 6 months
little return still not better even after replacing the N249 if not a better flow of ai decelerating on the MAF,
I restarted my replacement valve N75 mac and surprise
the plug to jump and more armature, reassembly of the old and logs again
it's less bad but still not his as you think the instructions and the current are not always there or staggered
So the valve broke apart?!
squarely like a popcorn yet it's a reinforced valve
Envoyé de mon FRD-L09 en utilisant Tapatalk
return to the box departure I go back the origin ca does not work too badly
I order this one I look forward to
http://www.vagdiscount.com/electrovanne ... -7090.html
N75 rises I redid logs I do not exceed the 1400 mbar and has 5/6000 tr the worst I desespere ...
It's really weird that the car is only asking for 1.4 bar. Possibly a defective ECU / MAP? What map is it running?
Interesting thread here that sounds a LOT like the problem you are having:
https://www.briskoda.net/forums/topic/3 ... -from-ecu/
Users browsing this forum: Google [Bot] and 147 guests
