rs6 c5 power loss and supercharging circuit leaks
Re: rs6 c5 power loss and supercharging circuit leaks
Hmmm. Something very not right. Another short circuit somewhere I think. Could your harness have melted again?
I know where it came from I wanted to buy the generic lambdas without connector audi and solder the son then thermo sheath and insulating tape but I fight to solder steel wire and not copper
Envoyé de mon POCO F1 en utilisant Tapatalk
I'll take care of it after I order the probe with the original connector on autodoc by typing the references are the same 4 only difference the color of the connectors but I would make landmarks
In the evening I looked at my problem I put pressure on the sural circuit and I heard a leak in the back of the block, I sent air in the wastegate pilot hose and the disaster pffff his escape to death and I act that the passenger wastegate I have to insist and send more Air to operate the second that answer to one of my questions to know why I had a offset to the flow meter j I want to cry that it is at the level of the T control wastegate is not accessible, I have the sight is at the mark 9 or the T or collar, hose but the olala
What a pain in the ass.
Oh well, at least you are experienced in dropping the engine.
I will try to see what is broken and put temporary hose if I can access the passenger wastegate
I know someone who's interested in this correlation between the wastegates actuators and the MAFs discrepancies.
I was able to extract the culprit is the T plastic, I prepare a set that I will go higher with 5mm hoses a T and collar ear crimp I protect the hose with sheath basalt
I already spend several hours to extract and shifted the wastegate hoses, and another hour this afternoon to put the hose back
Hours of fun when you own an RS6.
Have you driven it since repairing the T piece? I guess you need to fix the lambda sensors, too.
I have not yet mounted the hose with the T not had a lot of time, the lambdas will be secondary I will do them with a bridge I must buy one and make a slab to rest on it is still a budget of 1500/2000 € after to work it will be more practical
I will buy one of these 3 the
Big trouble the hose is too hard to nibble, side passage is not even worth it I ended up recommend silicone hose 5 / 6mm internal necklace ears and brass T it arrives in the week it will be easier to install the the less I can install it
Good idea. At least you won’t have to worry about it again. I wonder if Classk’s imbalance is coming from something similar.
it is very possible my leak must date for a moment t had to be split, to test it is necessary just to send air in the order of the wastegate
