Suspension PSS9 fitted
Posted: Sun Mar 19, 2017 7:29 pm
by SimonBurchett1984
Evening everyone
I removed the drc suspension last weekend and replaced it with pss9. Everything went well apart from one bolt! (Why does there always have to be one bolt? :thumbsdown: )
After driving it for the last week I'm still having some issues, there seems to be quite a lot of juddering through the suspension and sometimes pedals when going over potholes. There is way to many on the roads now!! I was wondering if anyone had any ideas what could be coursing this? It had an mot the week before last and passed with no advisories.
Re: Suspension PSS9 fitted
Posted: Sun Mar 19, 2017 7:31 pm
by Shoppinit
How low is it?
What number have you got the struts set on?
Posted: Sun Mar 19, 2017 7:32 pm
by Jayjay101
What were your top mounts like when you changed over the shocks? Mine where cracked badly.Also what are all your front arms like?
by Jayjay101
Image you can just see the cracks on the one on the left
Posted: Sun Mar 19, 2017 8:00 pm
It's about 10mm lower than what it was before I started, the struts where on 4 but turned then down to 2 to see if it would make any difference but it just made it a bit softer. Both my top mounts where cracked just like the Ines in the picture I brought front and rear replacements. All the front arms seemed fine I am planning on renewing the whole lot somewhen. Someone I've spoken to said maybe the subframe bushes?
Posted: Sun Mar 19, 2017 8:31 pm
by chunky79
Do you have play in your brake and throttle pedal bushes??
Posted: Sun Mar 19, 2017 9:45 pm
I haven't checked the pedal bushes, I'll check tomorrow. Are they easy to replace? If they are buggered it maybe adding to the problem. The car feels a little skittish over bumpy roads.
Posted: Sun Mar 19, 2017 9:49 pm
by chunky79
Nah, the bushes are a byatch to replace. I'd put money on it that they have play in them, and they really do make it feel like the suspension is loose and rattling.
Posted: Mon Mar 20, 2017 2:53 pm
by bilko1
I think there's a cable tie mod for the sloppy pedals, try a search on this forum.
Posted: Mon Mar 20, 2017 2:55 pm
by Shoppinit
On mine there is no juddering or vibration. However, the PSS9 don't like big bumps or dips as there isn't much travel before the springs bind. If you are hitting big defects and getting spring bind, that is an unpleasant sensation.
Posted: Tue Mar 21, 2017 2:11 pm
by V!per
that begs the question - Should I go for an Air Ride setup :nogarors4: :biggrin3:
Posted: Tue Mar 21, 2017 2:13 pm
by chunky79
Has anyone aired a C5 for every day use?
