I completely agree. Which is why I am on the struggle bus. The crank was locked using the locking pin. Not positive, but I think the tools came from eBay. I had to slightly bend the ends of the bar for them to be parallel to each other and fit on the rectangular washers. I have another cam bar ordered. I did not replace the rectangular washers. Is that really necessary?It's hard to reconcile what you are saying about the tools going on the cams OK with the kind of figures you are seeing.
Also, would the tension on the eccentric pulley play a significant factor in the timing? My understanding is that it is used to take up the slack and set tension (6NM CCW) on the belt while the damper pulley is in a locked position with the 5mm allen wrench. All this while the cams are locked in place with the bar and the cam sprockets are allowed to freely spin on the cam spindles. So the belt tension wouldn't have any affect on timing would it?
