Wind back rear caliper
Posted: Tue Jan 12, 2016 1:33 pm
by the cueball
Hi guys...
I'm just looking to double check that the RS has the wind back rears, and is there anything 'special' about them I need to know, like do I need to use
VCDS somehow with them?!?
Since I got mine back out of storage, the left rear is sticking quite badly, so I need to sort it out.
cheers!!
Re: Wind back rear caliper
Posted: Tue Jan 12, 2016 11:15 pm
by Mɐʇʇ
Yes, No, No, I think.
Posted: Wed Jan 13, 2016 5:45 am
by Jultsu
C5 has cables, not motors. No
VCDS required. Most windback tools will be for 38mm pistons, these have a 43mm piston and I had to use a lathe to make the tool seat properly around the piston.
Posted: Wed Jan 13, 2016 10:49 am
by TomRS
I just bought this
https://www.machinemart.co.uk/p/laser-5 ... Ajxy8P8HAQ
That worked on the back of my C6, and I'm sure its the same caliper just with EPB instead of cables (but don't know for sure)
Posted: Wed Jan 13, 2016 1:35 pm
by the cueball
thanks
Posted: Wed Jan 13, 2016 1:48 pm
by Jultsu
C5 has 22mm thick discs and C6 has 28mm, otherwise yes they seem to be identical in design.
Although there are only 2 holes in C5 pistons and they are at 180 degrees apart, that 3pin one doesn't seem like a good choice.
