Alternator output?
Posted: Tue Dec 29, 2015 6:08 pm
Anyone know roughly how many amp hours this puts out? Or more simply, how long do you have to drive it for once you have started it to put back the charge and a bit extra? Aircon and stereo were on as normal. I'd guess they would take 2 amps or so between them.
Started it today and it was barely turning over. It did start after a bit of a churn. I had used it at the weekend but it was the same then...After a short journey today it was again struggling to be bothered to turn over but at the weekend it wasn't. I then unfortunately had to drive around for about 90 minutes aimlessly in the hope that is enough to give it a decent charge. Dashboard voltage display is reading just under 14v when it is running so I'm assuming that is ok?
Battery is a few months old as it had a bad current drain and flattened the old one repeatedly so I changed the battery. Current drain was fixed so it can't be that.
I don't always need to use the car so it would be useful to know what's the minimum amount of time I'd need to take it out for if I didn't need it for a week or so.
