Page 1 of 2
vagcom headlight adaption help
Posted: Sun Dec 27, 2015 9:26 pm
by qaiserrs6
Hi iv got the warning light on the dash code p01539 headlights not adjusted and I cant seem to reset the problem.
Has anyone got the original stored headlight range adaption values for channels 1-7.
Re: vagcom headlight adaption help
Posted: Sun Dec 27, 2015 9:44 pm
by Shoppinit
Have you gone through the learning procedure?
Any error codes?
Posted: Sun Dec 27, 2015 9:51 pm
by qaiserrs6
yes it shows error group 001 not available.
a friend of mine tried having a go and hes changed the headlight range adaption channel values, so wanted to change them back to standard first
Posted: Sun Dec 27, 2015 9:58 pm
by Shoppinit
Are you in adaptation or basic settings?
/is this for a RS6?
Posted: Sun Dec 27, 2015 10:05 pm
by qaiserrs6
Yes for rs6 c5
Im in adaptation
Posted: Sun Dec 27, 2015 10:07 pm
by Trups
If you have an error on the dash it won't let you Adapt, is the car lowered?
by Shoppinit
That's where you're going wrong. Go to basic settings, group 001 then Go. Then up arrow to go to group 002 and that will learn the position.
Posted: Sun Dec 27, 2015 10:11 pm
by qaiserrs6
55-headlight range adaptation
mine is showing these values
channel = stored value
01 = 1
02 = 0
03 = 0
04 = 46
05 = 2
06 = 1
07 = 1
Posted: Sun Dec 27, 2015 10:14 pm
by qaiserrs6
Yes the car is lowered
Posted: Sun Dec 27, 2015 10:16 pm
by qaiserrs6
Shoppinit wrote:That's where you're going wrong. Go to basic settings, group 001 then Go. Then up arrow to go to group 002 and that will learn the position.
I have tried that it says error group 001 not available
Posted: Sun Dec 27, 2015 10:18 pm
by Shoppinit
Look in the measuring blocks to see what the level senders are reading.
Posted: Sun Dec 27, 2015 10:22 pm
by qaiserrs6
fronts are 1.72v and the rears 3.77v
Posted: Sun Dec 27, 2015 10:25 pm
by Shoppinit
That might be your problem. I think they have to be close to 2.5 to be able to learn the position.
Is your car level? I'm slightly surprised at the much higher reading at the rear, but maybe it's normal that it goes the other way.
Posted: Sun Dec 27, 2015 10:26 pm
by Shoppinit
if you can be bothered, might be worth jacking the car at a strategic point to get the values closer to 2.5 front and rear to see if you can complete the basic settings.
Posted: Sun Dec 27, 2015 10:31 pm
by qaiserrs6
ok I will give that a try, are my headlight range adaption values right?
