Trans Fluid - how much?
Posted: Fri Jun 19, 2015 6:40 am
by shadyraven
Hello all, planning a transmission fluid change for my RS6 i.e.) dropping the pan once and changing the filter. Question - how many liters of new fluid do I need to buy?
Re: Trans Fluid - how much?
Posted: Fri Jun 19, 2015 8:49 am
by Shoppinit
Capacity is about 10 litres, but you'll only get max 8 litres out. Probably a bit less than that.
Posted: Fri Jun 19, 2015 10:11 am
by Nobby
^ What Shopp said
Its also worth noting how much came out and how much went back in. Mine was very similar, even after accounting for the mandatory spillages.
I'd order some sump bolts if I were you. Loads of mine round very easily. They aren't tight though.
Posted: Fri Jun 19, 2015 10:19 am
by bam_bam
Nobby wrote:...even after accounting for the mandatory spillages.
Who's ensuring these spillages happen?
Posted: Fri Jun 19, 2015 10:42 am
by Shoppinit
A small sacrifice to the Audi God is customary.
Posted: Fri Jun 19, 2015 7:07 pm
by lswing
I think we got in about 12-13 liters including the cooler and lines last time we did a complete flush....you do have the manual and VCDS correct? Here's the link to it if you need.
I always like to go back a week later and double check to make sure it's topped off, easy enough.
http://audirssix.com/index.php/extras
Posted: Fri Jun 19, 2015 7:14 pm
by Mɐʇʇ
And if anyone's interested, this is one way to fill up the trans if you shorten the curved end to hook into the 'box, but it's a right ballache pumping away at it:
http://www.halfords.com/motoring-travel ... -mini-pump
But then it you mash it up with one of these:
http://www.halfords.com/motoring-travel ... -eezibleed
you can use the bottle and outlet from the minipump, with the cap & inlet from the eezibleed and you have the perfect, pressurised refill system. I recommend not going over 30psi or so though.
Posted: Fri Jun 19, 2015 8:34 pm
by tmg
This is the real deal but a bit pricey. Used it for my rs6, current s6, and gearbox, diffs and haldex on my superb combi, wife' dsg touran and a ton of others. The selection of ends is terribly useful.
http://www.ccw-tools.com/General-Transm ... 121-33798/
I believe that I got a few extra vag adaptors in my kit so it may not be this exact one.
