Page 1 of 4
Quarter mile times
Posted: Fri Jun 13, 2014 9:16 am
by rickster147
Hi will be getting some drag times next month at York
After stage 2 remap at MRC
Was just wandering if people can post there times down on here
And with what mods they have
Am curious of what time to expect I'm guessing about 13.5 quarter at 125mph
Also do you have a good tip with getting off the line fast with the auto box? :audibash:
Re: Quarter mile times
Posted: Fri Jun 13, 2014 9:36 am
by Nobby
I'm sure there are ways of doing it better but I wouldn't want to ruin the box (i.e foot on the brake and throttle etc).
Be interested to know if there are any differences in D, S or manual mode.
Posted: Fri Jun 13, 2014 9:59 am
by rickster147
Know what u mean with holding the brake on
Can't see the manual mode working well cause it changes up itself anyway
Posted: Fri Jun 13, 2014 10:02 am
by bam_bam
Nobby wrote:I'm sure there are ways of doing it better but I wouldn't want to ruin the box (i.e foot on the brake and throttle etc).
No difference in D vs S with WOT. Not sure about Tiptro, mines got 150PRM more but I'm not sure if that was achievable without being in Tiptro. You can easily fudge a short-shift close to redline after it shifts itself or too early. For a quarter run just stick it in S and mash the pedal. The best launch RPM (duck foot method) I found was 1500-1800RPM but that wasn't on a prepared surface. I'd imagine a drag strip would be pretty brutal on the 'box launching at higher RPMs.
Posted: Fri Jun 13, 2014 10:20 am
by IanH755
I've done two runs in my Stage 1+ MRC mapped car. The first one was in "S" with EPS off and just mash the throttle and got 12.5sec @112mph. Second was in "S" with EPS off and left foot on the brake to raise the revs to 1800/2000rpm and got 12.19sec @ 111mph but thats the only time I've done left foot braking and I wouldn't do it again just to be kind to the gearbox.
Times below measured using 10hz GPS receiver (same as VBox) from our rally car's telemetry setup and Racechrono software (the most accurate version is Sybian only hence the old phone to rum it).
The second run got much better acceleration off the line but was slightly slower in the 40-80mph so 2nd to 3rd gear change was slower I'd say.
Posted: Fri Jun 13, 2014 10:26 am
by rickster147
How accurate are those gps devices tho ?
You might of had a slight decline as it would be hard to find a road that's level?
Posted: Fri Jun 13, 2014 10:37 am
by IanH755
They are very accurate, less than 100th of a second difference between one of these and a rull racelogic setup with 20hz GPS costing £15K+ according to testing done by Fifth Gear etc. The "road" (I work on an airfield and use a a bit of taxiway) was the same for both runs is has a slight incline towards the end and it isn't a proper "drag" prepared strip etc and as such my times mean *censored* all other than as a personal benchmark so I can see if any further upgrades make a difference when tested using the same kit, same road and same car.
As an aside, when I had by 450hp R34GTT (RWD) my best times at Santa Pod were all around 13.9sec @ 110mph as I couldn't get off the line without wheel spinning constantly (very bad technique). The difference AWD makes is quite impressive!
Posted: Fri Jun 13, 2014 10:52 am
by rickster147
Impressive is12.2 do u think i will be in a shot for similar times
Posted: Fri Jun 13, 2014 11:07 am
by IanH755
With a stage 2 you should be running around 530hp I think so the times & speed won't be greatly different as it's "only" 30hp difference *however* on a proper drag strip with better grip and timing devices etc you should get a more accurate idea of what your car is capable of. My guess would be around 12-12.5sec @ 112mph-118mph depending on how you launch.
Posted: Fri Jun 13, 2014 5:28 pm
by LunarWolf
Does MRC not offer a launch control mod?
I had one on my SuperV8 and it was the absolute nuts!
Was quicker than most manual cars of the same ilk!!!
Ask them! It can't hurt!
Posted: Fri Jun 13, 2014 6:43 pm
by mavada
...it hurts the box...
Posted: Fri Jun 13, 2014 6:58 pm
by LunarWolf
...Not if it's done right....
Posted: Fri Jun 13, 2014 7:07 pm
by mavada
...if the box is done, iow, 517 treated...
Posted: Fri Jun 13, 2014 7:15 pm
by sakimano
rickster147 wrote:Hi will be getting some drag times next month at York
"these cars weren't made for the dragstrip"
"A true test is to put the car around a few corners"
"why would you lower yourself and the RS by taking it to the dragstrip"
"there are too many variables at the dragstrip"
"Audis are made for road courses, not going straight"
"the dragstrip is too hard on the car" (usually posted by track day regulars sporting torched sidewalls, rotten ball joints and worn brakepads and rotors with hotspots)
"Any moron can shift gears in a straight line...you should try running the TT course at Isle of Man if you want a real test"
etc
Just figured I'd save the usual forum douchebags some time and post their pea-brained responses for them.
Have fun out there. Remember to shallow stage. It can change your time by 0.2-0.3 seconds. Also, don't worry about reaction time...lots of people think it matters. It doesn't unless you're bracket racing.
Posted: Fri Jun 13, 2014 7:29 pm
by LunarWolf
true true! :)
