Passenger Seat Electric Adjustment Partial Fail
Posted: Fri May 09, 2014 11:00 am
by saulcupra
Hi All :bigwave:
I tried to adjust the electric passenger seat forward this morning, with no joy, not even a hum from the motor, it also wont go back either.
However, the electric backrest, height adjust and lumbar support all work fine.
Im puzzled, is there a motor for each moving part, or is it all geared to one?
Anyone else had a similar issue?
Thanks in advance for your knowledge!
:beerchug:
Re: Passenger Seat Electric Adjustment Partial Fail
Posted: Fri May 09, 2014 12:35 pm
by Maximo
There are different motors for each movement. Have you done anything under the seat recently? If so it could just be a connector that's popped out as your not getting a noise.
Posted: Fri May 09, 2014 12:42 pm
by saulcupra
nothing at all buddy, ill raise it up and take a peek later
Posted: Fri May 09, 2014 12:46 pm
by rickster147
Since I bought mine I noticed my lumbar support doesn't work but rest is fine
Posted: Sat May 10, 2014 11:46 am
by Maximo
Have you looked at this thread? http://forum.rs246.com/viewtopic.php?f=2&t=109346 It may offer you a little help.
Posted: Sun May 11, 2014 6:23 pm
by drybeer
On my drivers seat I get this occasionally. I think the electric switch is just dirty. I will eventually get around to spraying electrical cleaner in it if I can get it taken to bits. As far as I know Audi will only sell the whole side panel of the seat including the circuit board and switches as one part.
Posted: Tue May 13, 2014 9:32 pm
by philroach
Loose connection under the seat...
