Gearbox strip down conclusion
Posted: Sat Feb 22, 2014 2:22 pm
Hello all,
Right then, my car is currently down at Automatic Transmissions in Preston where the gearbox had been overhauled last year.
Since then it started to flare in between 1st and 2nd gear change, almost as if it disengaged 1st gear and was slow to engage 2nd. If i held the throttle at WOT in between gear changes it would eventually engage 2nd gear with a heavy thud then continue to rev as normal. This situation was getting worse and worse to the point where i could take off fairly easy in 1st then select 2nd, if i then pressed the throttle down hard in between 1st and 2nd gear change i could get it to rev to the red line quite easily before 2nd would eventually engage.
First of all a new valve body was fitted and the car test driven with no difference to my problem.
I was sure my 2nd gear clutch pack was worn or had a nipped "O" ring somewhere reducing pressure in the system, however following strip down there was nothing untoward found, all clutch packs were found to be in good condition with no signs of slippage or excessive wear.
Since the box was stripped down he fitted a new second gear clutch pack, new seals throughout, new piston for 2nd gear and a new hydraulic accumulator damper, the car is going back together now with a test drive on Tuesday hopefully.
The chap who built the box, who has many years specialising in this profession said he was not surprised to find no mechanical wear or damage and believes it's a software related issue where the software has started to drift. Not sure what exactly that means??
I explained to him that this issue started when i tried sports mode one day then went down hill from there starting to flare in tiptronic then eventually in drive over a period of a few weeks.
I'm just not convinced on the software theory but since there was nothing found when the box was stripped down I'm out of ideas.
Is there any advice you guys can give me?
Thanks in advance.
Gordon
Thanks in advance.
Gordon
