Page 1 of 2
New brakes
Posted: Fri Sep 20, 2013 6:10 pm
by smichels
I got myself some new brakes.
Re: New brakes
Posted: Fri Sep 20, 2013 6:12 pm
by chunky79
Welcome from Australia.
Re: New brakes
Posted: Fri Sep 20, 2013 6:17 pm
by mavada
Re: New brakes
Posted: Fri Sep 20, 2013 6:28 pm
by Shoppinit
It looks like a doily.
Re: New brakes
Posted: Fri Sep 20, 2013 6:53 pm
by Mr Footlong
Not being a hater, I first saw these at ADI last year. Not a fan I am afraid
. Once they have lost their shineyness they will probably look better.
Re: New brakes
Posted: Sat Sep 21, 2013 9:07 am
by mavada
...whats the purpose of the shape?
Re: New brakes
Posted: Sat Sep 21, 2013 11:16 am
by bilko1
Ask the motor bike boys, they have been using wavey discs for years.
Re: New brakes
Posted: Sat Sep 21, 2013 12:23 pm
by armyair
mavada wrote:...whats the purpose of the shape?
According to Audi improved airflow and cooling
Re: New brakes
Posted: Sat Sep 21, 2013 8:18 pm
by HYFR
No
Weight saving.
armyair wrote:mavada wrote:...whats the purpose of the shape?
Re: New brakes
Posted: Sat Sep 21, 2013 8:59 pm
by ahoooga
For the amount of weight they'd save , I'd be better off emptying the ashtray instead
Re: New brakes
Posted: Sat Sep 21, 2013 10:06 pm
by HYFR
Think it was 1.2kg each iirc
Re: New brakes
Posted: Sun Sep 22, 2013 1:53 am
by armyair
D_K wrote:No
Weight saving.
Looks like we are both right!
http://www.audi.co.uk/about-audi/latest ... avant.html
Quote Audi
"High performance wave disc brakes
Mounted behind the large wheels are internally vented wave disc brakes with high gloss black-painted callipers. The front callipers with their eight pistons and prominent RS logos measure 365 millimetres in diameter. The steel friction rings with their wave-like outer contour are perforated and connected to the aluminium brake caps via pins. This concept reduces tensions, quickly dissipates heat and prevents transmission of temperature peaks. The new shape of the friction rings shaves a total of roughly three kilograms off the unsprung weight."
Weight saving on R8 is a total of 2kg according to literature so obviously differs according to rotor diameter/radius.
As an engineer I would guess the primary design objective would be to increase the edge surface area to aid cooling and a by-product is weight saving as there are far easier ways to save weight without effecting the rotational mass and balance however it's easier for marketing men to sell weight saving!
Re: New brakes
Posted: Sun Sep 22, 2013 4:29 am
by bam_bam
Nice work! Spill the beans. Were these a straight bolt-on or is there some blackmagic going? New 8pots or did you spruce up your C5 8pots?
I'd be interested in the rear setup, can you post some pictures.
Also, I've developed a pure hatred of the door badges. Please crop or potatochop them out of all future pictures. That is all.
Re: New brakes
Posted: Sun Sep 22, 2013 8:16 am
by JCviggen
Looks interesting, probably need to see the car IRL to figure out if it looks "right" or not though.
It's losing styling points for misplaced badges, but worse than that the gigantic wheels make the stock brakes look too small. Should've gone to a larger C6 setup to restore balance instead of messing with wavy rotors. That would count as an upgrade and isn't really that expensive (surprisingly)
Tough crowd, I know.
Re: New brakes
Posted: Sun Sep 22, 2013 8:20 am
by el_ringo
How big are they? The look a tad small.
