front end fan.
Posted: Mon Jul 08, 2013 3:40 pm
by the6
comes on full tilt on start up and continues like it all the time the car is running, when the car is off, the fan will lower in tone slowly and then run for approx 4 mins.
Its sounds like an aeroplane, not noisy but irritating. Can I do anything to stop this? I don't want to map it out (if there is such a fix) bviously fan is there for a reason....But I cant help but think its not normal?
Re: front end fan.
Posted: Mon Jul 08, 2013 3:44 pm
by rich
I was going to post this. Just wasn't sure if it was supposed to do that. Every single journey it comes on, sounds like its a fighter jet spooling up.
Re: front end fan.
Posted: Mon Jul 08, 2013 3:51 pm
by Nobby
Is your aircon on? If so the fans are in hyper mode.
Re: front end fan.
Posted: Mon Jul 08, 2013 3:52 pm
by the6
Aircon fan off.... Its bizarre and bloody noisy..
Re: front end fan.
Posted: Mon Jul 08, 2013 5:03 pm
by Shoppinit
Either the thermostat, the temp sender or the fan control module is borked. I'm guessing the first. Check your water temps with
Vagcom or on the A/C display.
Re: front end fan.
Posted: Mon Jul 08, 2013 5:09 pm
by R8GXR
Shoppinit wrote:Either the thermostat, the temp sender or the fan control module is borked. I'm guessing the first. Check your water temps with vagcom or on the A/C display.
How do you chek the water temps on the AC display?
Re: front end fan.
Posted: Mon Jul 08, 2013 5:17 pm
by Shoppinit
Re: front end fan.
Posted: Mon Jul 08, 2013 6:37 pm
by ahoooga
Although it was started a long time ago , i think its well worthy of being made a sticky
Re: front end fan.
Posted: Mon Jul 08, 2013 7:33 pm
by the6
Thermo!!!??? Noooooooo only bought it as it had thermo done when belts changed recently etc... Faxering fookerfudz..
Anyone got a 'Gina' com any place near me? (Sussex).
ARSE
Re: front end fan.
Posted: Mon Jul 08, 2013 7:37 pm
by the6
Water temp on dash always been same, 90..
Re: front end fan.
Posted: Mon Jul 08, 2013 8:02 pm
by Shoppinit
The dash gauge is fairly meaningless until the temp gets properly out of whack.
Could just be a faulty fan module.
