Page 1 of 2
Engine cutout won't restart
Posted: Thu Jan 10, 2013 10:05 pm
by Nemesismoo
Tonight on my way home from work My RS6 cutout & won't restart
Engine turns over - probably a bit faster than normal but just will not start - after a while of cranking Engine oil level warning comes up.
Was thinking fuel related - pump / relay maybe as turning faster than normal.
Re: Engine cutout won't restart
Posted: Thu Jan 10, 2013 10:10 pm
by MikeFish
Did you stop a bit suddenly or hit a big bump? I assume these audi have fuel cut off valves which turn cut off the fuel supply electronically?
All my old cars used to have them hidden in the car and would need resetting before the car would start again. Obviously if you stop a bit to sharpish it should activate it but you never know. Always handy to know where they are on your car.
Posted: Thu Jan 10, 2013 10:21 pm
by Nemesismoo
Had just gone over a speed bump, so not sure???
Posted: Thu Jan 10, 2013 10:51 pm
by MikeFish
Ok, a little delving online and it seems that on audis with airbags the fuel cut off will only kick in when the airbag is deployed so I don't think that is your problem.
Posted: Thu Jan 10, 2013 11:14 pm
by Nemesismoo
Ah right - well its not that then, think I might have noticed that. Thanks for looking though
Posted: Thu Jan 10, 2013 11:42 pm
by el_ringo
Enough fuel in it? The gauge is a know liar and could be dead
Posted: Thu Jan 10, 2013 11:54 pm
by Nemesismoo
el_ringo wrote:Enough fuel in it? The gauge is a know liar and could be dead
Loads in it - £70 yesterday & done about 4 miles since
Posted: Fri Jan 11, 2013 12:14 am
by ElevenSec
Nemesismoo wrote:Tonight on my way home from work My RS6 cutout & won't restart
Don't like the fact that the Engine turns over faster than normal. That could be the sign of a Failed Timing Belt. Hope not as that could be catastrophic.................
Posted: Fri Jan 11, 2013 12:16 am
by Nemesismoo
ElevenSec wrote:Nemesismoo wrote:Tonight on my way home from work My RS6 cutout & won't restart
Hope not, was only changed 8K ago
Posted: Fri Jan 11, 2013 1:37 am
by MikeFish
I've heard loads of engines turn faster than normal over the years and never anything serious so wouldn't let that bit worry you.
Posted: Fri Jan 11, 2013 1:52 am
by ElevenSec
[/quote]
Since it was changed only 8K ago, then the Cam belt shouldn't be an issue, but you never know. Hope it turns out to be something simple such as a fuel pump or an ECU. To really find out you will have to VAG it with a Ross Tech and see what Fault Codes you come up with.......
Posted: Fri Jan 11, 2013 7:50 am
by chunky79
Is the immobiliser light flashing? Can't remember if it cuts the fuel or start out.
What fuel did you put it?
Wait for Shopp to wake up.
Ooooooo, another thought. How about checking the wiring under the scuttle cover. Had a car on here last week that lost power due to the wiring being corroded, perhaps you have a fault there with a particular wire?
Posted: Fri Jan 11, 2013 7:55 am
by mavada
chunky79 wrote:Is the immobiliser light flashing? Can't remember if it cuts the fuel or start out.
Posted: Fri Jan 11, 2013 8:07 am
by Shoppinit
Could be lots of things. You need to get a
Vagcom / obd2 diagnostics on it.
Crank position sensor seems to be a common one.
Posted: Sun Jan 13, 2013 10:15 pm
by Nemesismoo
Cars in garage now audi/bmw/merc specialists so just waiting to hear from them now......
Have only had the car 2 weeks as well
