Headlight condensation
Posted: Mon Nov 26, 2012 1:13 am
by Supraholic
Apologies, have tried using search but I can't find instructions on how to get rid of condensation in the headlights.
Can anyone help. :|
Re: Headlight condensation
Posted: Mon Nov 26, 2012 7:47 am
by chunky79
Try Google mate, there will be links to videos how to do it too on there. The only way i know is to put the headlight in the oven to help remove the lens, then dry it out and clean it.
Posted: Mon Nov 26, 2012 11:35 pm
by Supraholic
OK, thanks
Posted: Tue Nov 27, 2012 12:47 pm
by bam_bam
Am I correct in thinking that if you've got condensation showing then the units aren't airtight? Once the tar has been heated, unit cracked open and cleaned, can you leave one of those silica packs inside or it that a danger?
BTW I don't have this issue but I have had on other cars and this was my general way of dealing with it (passed on to me by my grandfather).
Posted: Tue Nov 27, 2012 2:29 pm
by Nobby
Hairdryer has always worked for me, remove the unit and pull a bulb out. Hairdryer on hot and stick it in the hole.
Sealing it back up is the problem.
Posted: Thu Nov 29, 2012 3:27 am
by el_ringo
Can you remove it and put in a sealed box with lots of rice? Worked a treat for stuff the boy has put in the washing machine.
Posted: Thu Nov 29, 2012 8:00 am
by chunky79
Nobby wrote:Hairdryer has always worked for me, remove the unit and pull a bulb out. Hairdryer on hot and stick it in the hole.
Hair dryer? What's one of them?
Posted: Thu Nov 29, 2012 8:25 am
by swannny
Me and you would call it a towel Dunc!
Posted: Thu Nov 29, 2012 9:06 am
by bam_bam
Ha.
Posted: Thu Nov 29, 2012 11:52 am
by RobM
A hairdryer is a useful addition to one's toolbox. It is commonly used to warm things up and dry them out. Typical applications include removing unwanted vinyl 'stickers', speeding up epoxy set-times and drying condensation out of headlamp shells.
A top-tip is never let your wife/girlfriend see it. They'll want to do all sorts of crazy stuff with it and returning it to it's rightful place, in the workshop, may well prove troublesome.
Good luck.
Posted: Thu Nov 29, 2012 11:55 am
by RobM
Nobby wrote:Hairdryer on hot and stick it in the hole.
This may also cause issues and unrest in the home. It should never be attempted without full consent of the other party.
Posted: Thu Nov 29, 2012 12:00 pm
by brn7y
You don't need the whole silica pack just drop a couple of beads inside, they roll about but you don't really see them.
Posted: Thu Nov 29, 2012 1:39 pm
by bam_bam
Meh, I find it's easier to beg forgiveness rather than seek permission.
Posted: Thu Nov 29, 2012 2:00 pm
by Golfather
Condensation means theres a leak in the seals or the unit has a crack somewhere.
Check backing of unit to ensure tight seal and around front of headlamp.
Check breather pipes to ensure they are not blocked.
No point in just drying it out as it will just come back.
Was a very common prob on the early C6's which was rectified by a repair kit consisting of a new backing seal, and redesigned breathers.
Posted: Thu Nov 29, 2012 3:02 pm
by RobM
Hardcore ....and a touch disturbing. :shock:
