Knock sensor help please
- Human Joist
Re: Knock sensor help please
Will do mate. Changing the plugs now. Will spray all connections first and try it again. It shows it as an intermittent fault. The fact I can’t find anything on these forums lends me to believe they don’t normally play up
Yeah, I don't remember coming across a failure before. You must just be lucky.
- Human Joist
This valve should I just get it off eBay or do I need to look at genuine. They appear to only be £8
- Human Joist
By way of an update. Inlet manifold off. Lovely job
. Faulty knock sensor ordered. Jet valve pipe ordered as it broke coming off. Secondary coolant recirc pump didn’t work when tested so ordering one tomorrow along with new inlet manifold gaskets. Then will start and put it back together
Why are your DVs connected together?
- Human Joist
Hadn’t touched that pipe work. What should they be connected like then ?
- IchBautAuto
These are alloy DV and I've changed them out for GFB products but you can just see the vacuum pipework, marries and then to the vacuum source. 7zap or the equivalent should give you the actual pipe layout.Human Joist wrote: ↑Mon Jul 20, 2020 10:27 pmHadn’t touched that pipe work. What should they be connected like then ?
- Human Joist
Ok. Clearly this set up is wrong on mine then I don’t have access to any manuals for how it should be. If you have could I ask you drop some images on so that when I stick the inlet back on I can ensure the correct flow for the vac lines. What would be the cause of them being out on wrong. Will it damage anything or just stop it working correctly
Interesting that your after run pump is mounted on the engine. The one on the spare engine I have is mounted on the under side of the inlet manifold.
The DVs definitely won't be doing what they are supposed to be doing so your turbos will be being brakes by the throttle valve when you lift off. Probably won't cause any damage, but you'll effectively be losing performance.
Makes you wonder where the plumbing that was supposed to be going to them is going, though. That could be a source of problems. Biggest concern is probably vac leak.
I wonder if it's because yours is the other type of cooling circuit. Do you know your production month?
- Human Joist
Ok. Here is the set up at the moment. Will buy a Bentley manual too
- Human Joist
Could you show us where your pipe work goes please ? As after the meet they then t off. Just wondering if the connection is just further along on yours
