Running like <beep>...
Re: Running like <beep>...
Post by Shoppinit » Mon May 11, 2020 7:02 pm
Maybe the plug wasn't in properly and now it is. Unburned fuel woud cause the trim to be off. Driving it slowly correct the trim. Maybe they didn't clear the fault code properly. Have you checked it since?
Mark-RS
Post by Mark-RS » Mon May 11, 2020 7:43 pm
Not checked it for codes yet, other than directly after I ran it and took it back, when it read cylinder 1 again. It stuttered for maybe only a few minutes and then cleared. The light flickered, but didn't stay on.
He did also say that the plug was incredibly tight when getting it out, at first he thought it may have been cross threaded, and then when he got it out, said it looked like the garage that fitted them had put copper grease around the threads which was apparently not a good thing. I'll have a check tomorrow for codes again.
Think I will clear any codes and then run the car for a bit, then read again.
steve2003rs6
Post by steve2003rs6 » Mon Jun 01, 2020 7:29 pm
Hi mark-RS. How is the car now. Did the plug problem cure the fault.
Hope all is ok now. Regards Steve.
Mark-RS
Post by Mark-RS » Mon Jun 01, 2020 7:42 pm
Yes ! Forgot to update this. Bought a new plug and instantly it ran smooth as it always had. No codes anymore either.
Plug itself looked just fine though, which was strange.
Going to replace all of them again in the next month or so, just to be sure. How many miles should plugs cover before being changed on these things ?
steve2003rs6
Post by steve2003rs6 » Mon Jun 01, 2020 7:56 pm
I have mine changed every year when i have service done. and i make sure that the correct plugs are fitted (ngk) last garage fitted bosche plugs i now use unit 20 for all work done to my car.
pleased yours is sorted .Been following this post with interest
Post by Shoppinit » Mon Jun 01, 2020 8:02 pm
Shoppinit wrote:
Sun Apr 19, 2020 5:08 pm
I suspect that the problem is either a faulty plug, plug not properly torqued.
:bigwave:
steve2003rs6
Post by steve2003rs6 » Mon Jun 01, 2020 8:17 pm
Ha ha. That’s why you get paid the big bucks shopp ???????
Post by Shoppinit » Mon Jun 01, 2020 8:20 pm
Gotta blow my own trumpet these days.
Astrosquirrel
Post by Astrosquirrel » Tue Jun 02, 2020 8:06 am
Damn you're flexible :P
...your knowledge on these cars never ceases to astound me though :bowdown:
steve2003rs6
Post by steve2003rs6 » Tue Jun 02, 2020 8:26 am
Yeah. Gotta echo the above. And he never seems to sleep.
Mick Dundee’s got a Donk
Forums got a shopp !
Fish chips and no peas still available shopp.
Users browsing this forum: No registered users and 58 guests
