Judder
norwichphoto
Judder
Post by norwichphoto » Sun Nov 30, 2025 12:17 pm
My car has started to develop a judder. It manifests itself whilst decelerating, at around the 30mph area +- a few miles. Car pulls up straight. It seems to do it in neutral as well as drive, but that doesn't necessarily rule out a transmission problem. It doesn't seem to do it whilst accelerating.
Any thoughts?
Everyday: 2003 Audi RS6 C5 Saloon in Avus Silver, with black leather upholstery (for sale)
Fun: 1977 Lancia Montecarlo Evoluzione track car. (wife approves)
Wife: RenaultSport Clio RS200
Previously: Toyota Seras (several), TVR Chimaera 400, Mercedes Benz C43 AMG, Toyota Altezza RS200 etc.,
Re: Judder
Post by Shoppinit » Sun Nov 30, 2025 12:50 pm
Could be inner CV joint or central propshaft bearing.
30mph is where the box changes down too (slightly annoyingly), so it might be the torque converter lock up clutch. Or maybe it's just that the change down to 2nd introduces more engine braking, proportionally, causing the vibration to be felt in one of the above.
Does it do it if you hold 1st or 3rd with the tiptro when decelerating past 30mph? Not sure you can get the box to do 1st at 30. Maybe just use the tiptro to prevent gear change to rule out TC.
Re: Judder
Post by Shoppinit » Sun Nov 30, 2025 12:53 pm
Oh, just spotted it does it in neutral. Do those tests anyway. You never know. That would seem to rule out anything engine regime related, too.
Does it do it if you don't brake?
norwichphoto
Re: Judder
Post by norwichphoto » Sun Nov 30, 2025 5:46 pm
Will try those tests.
I can feel it through steering wheel so its a front axle issue. I'll see if I can use tiptronic and force a different gear.
Re: Judder
Post by Shoppinit » Sun Nov 30, 2025 5:53 pm
I wonder if the tracking has gone out. Maybe check the condition of your bushes.
norwichphoto
Re: Judder
Post by norwichphoto » Mon Dec 01, 2025 2:04 pm
It doesn't seem to do it whilst coasting.
It doesn't appear to do it whilst maintaining a steady speed around this speed.
So I think its something worn which as magnified during the braking process around that speed, so will check lower arm bushes first.
norwichphoto
Re: Judder
Post by norwichphoto » Mon Dec 08, 2025 6:57 pm
Hmm. CV joints and propshaft joints all seem to be OK. No excessive play in wheel bearings. A little too much run-out on rear discs (they're original). When driving it feels as if its front axle related, but there are times when its turned out to be the tail wagging the dog.
