EGT sensors
Steve2003rs6
EGT sensors
Post by Steve2003rs6 » Sat Oct 18, 2025 11:54 am
Hi all.
Been a bit busy just lately with appointments.
So I haven’t scanned the car for some time.
Scanned this morning and EGT errors came up on both sensors.
Not too worried at the moment as I saw a new pair for sale. Couldn’t resist them so I bought them even though they were bloody expensive. Any recommendations appreciated as always.
TIA
Last edited by Steve2003rs6 on Sat Oct 18, 2025 12:10 pm, edited 2 times in total.
Re: EGT sensors
Post by Shoppinit » Sat Oct 18, 2025 12:04 pm
Hmm. Hard to believe that both failed at the same time. Clear the codes and see if they come back. You don't want to be changing those if you can avoid it. The access is a nightmare.
Maybe they were unplugged from inside the engine bay at some point recently?
Steve2003rs6
Re: EGT sensors
Post by Steve2003rs6 » Sat Oct 18, 2025 12:06 pm
Hi Ben.
Yes mate I wondered about both failing at the same time.
Both say intermittent faults.
I have cleared them.
Check again in about a week or so.
I don’t think they have been unplugged.
I did have the exhaust coupling/sleeves replaced a few weeks back.
Mɐʇʇ
Re: EGT sensors
Post by Mɐʇʇ » Tue Oct 21, 2025 9:26 am
If they are originals they had a softer potting compound on them that was easy to remove so that you can often resolder & repair in-situ. IIRC it's usually just the connector solder joints that give up. That later EGTs had a much harder potting compound that might not be possible to remove - but perhaps also gives a bit more support so the solder joint doesn't fracture in the first place.
Steve2003rs6
Re: EGT sensors
Post by Steve2003rs6 » Wed Oct 22, 2025 10:19 am
Thanks for the info Matt.
Yes mate they are the originals.
Going to leave it for a week and then rescan to see what comes back.
Steve2003rs6
Re: EGT sensors
Post by Steve2003rs6 » Fri Oct 31, 2025 11:36 am
Just re scanned the car.
No EGT warnings. Either it was a blip or the garage had disturbed something when they installed the new exhaust pipe sleeves. I did have a minor exhaust gas leak at the joint. The new sleeves rectified the exhaust fumes leak.
Marcin
Re: EGT sensors
Post by Marcin » Fri Jan 02, 2026 1:21 pm
Thats a win! I had issues with one EGT, but a quick solder job fixed the problem. I believe to replace EGTs you need to drop the engine..... :shock:
Is:
2003 RS6 | 2013 A6 BiTDI quattro | 2016 Corsa ;) | Suzuki GSX-R 1000 K6
was:
2004 A6 3.0TDI quattro | 2000 A6 1.8T quattro | 1997 A6 1.8 | 1998 Opel Vectra 1.6 | 1985 VW Santana |
Users browsing this forum: No registered users and 115 guests
