Rear view mirror sticky pad
bilko1
Post by bilko1 » Wed May 21, 2025 12:31 pm
Does anyone know where I can get the sticky pad for the rear view mirror please? I bought a new mount from Audi but it does not have the sticky pad on it. I have tried some from Halfords but they were useless also tried some expensive 3M double side tape but still wont hold the mirror to the screen.
Re: Rear view mirror sticky pad
Post by Shoppinit » Wed May 21, 2025 1:02 pm
I thought the mirror clipped onto the stud bonded to the screen.
Steve2003rs6
Post by Steve2003rs6 » Thu May 22, 2025 9:22 am
Paul. As Shopp says.
Even had a new windscreen. And the fixing comes already bonded to the screen.
And it is well and truly bonded. Had to use molegrips in the past to turn the mirror to remove it.
Suitable packing used so you don’t damage the plastic.
Like when I fitted the “mirror John”, upgraded rear view mirror.
bilko1
Post by bilko1 » Thu May 22, 2025 10:52 am
I know what you guys mean as I've had a new screen myself. But looking at whats left on the mirror it is some sort of sticky pad. Maybe I'll have to accidentally crack the windscreen and claim on the insurance :bigblink:
Steve2003rs6
Post by Steve2003rs6 » Thu May 22, 2025 11:38 am
Paul from memory. To remove the mirror you turn the mirror approx 45 degrees acw.
With the mirror removed the post remains on the windscreen.
From your photo is that the post that has come away from the screen ?
It should by bonded to the screen. Which is very secure. Double sided tape etc is not strong enough mate.
I have known of owners that have broken their windscreen trying to remove the mirror.
The bonded post is that secure.
bilko1
Post by bilko1 » Thu May 22, 2025 12:33 pm
I've ordered Permatex 81840 Extreme Rearview Mirror Professional Strength Adhesive to try. If this dosen't work a new screen will be sorted.
Steve2003rs6
Post by Steve2003rs6 » Thu May 22, 2025 2:07 pm
Yeah mate that’s worth a try first.
New windscreen can be a bigger problem.
All depends on the installation fitter.
Had mine done and I wasn’t happy. Had a gap each end. They fitted a A6 screen which isn’t the same size.
Shortly after got two pebbles kicked up by a truck in front of me.
Then fitted a genuine Audi screen which was very costly around £500 iirc.
Perfect fit. But install wasn’t great.
Capt Ric on here got the right screen for a fraction of the price. Only difference was mine had the 4 Audi rings etched on it. Captain Ric screen didn’t. Both had same part number.
I think I said to Ric at the time. The 4 Audi rings on my screen cost me £100 each.
There is a full story on here about it somewhere.
Post by Shoppinit » Thu May 22, 2025 2:33 pm
Don't talk to me about windscreens. The thought of replacing it on the RS6 again makes me shudder.
bilko1
Post by bilko1 » Thu May 22, 2025 4:28 pm
I've been through the windscreen hassle, took Autoglass 3 atempts to get it right last time and they ended up putting a genuine screen in.
TOPMAN
Post by TOPMAN » Sat May 24, 2025 7:07 am
Hi Paul
Hows this going?
I did do a bit of research on this after our last conversation, seem the rearview mirror kits can work quite well. But failing that, another option would be to take it to an AutoGlass place where they use a UV-curing cyanoacrylate adhesive. So there is an option other than breaking the windscreen :-)
If you do get the button to stick (based on what I have read 1 week is best) then you will want to grease that mirror before fitment. They are crazy tight! A bit of white lithium with a cotton bud sounds good to me :-)
Regards
Craig
TOPMAN
Post by TOPMAN » Sat May 31, 2025 6:39 pm
Has this moved forward buddy?
bilko1
Post by bilko1 » Sat May 31, 2025 9:36 pm
Yes, glued the button on with the Permatex 81840 Extreme Rearview Mirror Professional Strength Adhesive, First attempt didn't work so I did it again and dared to use 2 drops and it has worked. Brutus is pretty much all up together now just the tailgate water leak to sort out.
TOPMAN
Post by TOPMAN » Sat May 31, 2025 9:37 pm
Brilliant
